Question about HP Photosmart A616 InkJet Printer
HP A616 photo printer. Cartridge Failed Message keeps popping up
The original cartridge worked perfectly until it ran out of ink. ProbabIy printed around 30 pictures or so. I put in a new HP cartridge, print maybe 5 to 6 pictures and the "Cartridge Failed" message comes up and the unit will not work. I take the cartridge out, clean the contacts and the print head and put it back in and turn the printer on, instantly the failed cartridge message comes back up. I go buy another (quite expensive I might add) cartridge, and the same thing happens all over again. What is up with this and how the heck do I fix it?
Thank You
  • Anonymous Apr 30, 2009
    instantly the failed cartridge message comes back up. i take it in and
    out severl times and then it works. What is up with this and how the
    heck do I fix it?
  • 75 Answers
First thing is never mess with the contacts on the ink cartridge carrier. Now that you have touched the contacts they get a film on them and don't work right after that. I had the same thing had to replace the cartridge carrier more than once. Find out how much a new one will be, then if the price more than want you think the printer is worth, you might be cheaper to buy a new printer, but don't indulge in a big expensive one because some of the cheaper ones do just as good as an expensive one and costs less to operate with the same quality. compare the price of ink also if you decide to have to get a new printer.
Posted on Nov 18, 2008
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
New ink cartridge won't print
Do you know for sure the original cartridge was empty? Take a clean pencil with eraser, and gently "erase" the electrical contacts on the cartridge and the printer where the 2 connect. See if that helps. If it is USB, unplug it and plug it back in. You might try to uninstall and reinstall the driver for the printer.
Aug 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Won't Print After Changing Ink Cartridge
Did you pull the plastic tape off of the cartridge?
Jan 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Replace color cartridge
Access your printer properties and try preforming a print head or printer cartidge clean and on the machine try the print cartridge aligniment procedure.
If after you try both of those I suspect there is an issue with the print head.
If that is the case an ink jet printer is not worth repairing.
Dec 20, 2007 | HP PhotoSmart 7760 InkJet Printer
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart A616 InkJet Printer Logo
349 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
