Question about RCA F32672SB 32" TV
The picture is convexed,or hour glass.
I am not getting a full screen picture,there are margins on both sides,convexed looking. How can I fix the hour glass picture on my tv?
  • CHERYL MORGAN Dec 28, 2006
    How can I fix this?
  • Satans Candy Apr 18, 2009
    I have the exact same problem but, also the bottom left corner turned purple! I lost my remote so now I cant switch to Input to play my XBOX either! BOOOOOO!
  • 7 Answers
Sounds like problem in B+ voltage line to horizontal output transistor. Possible bad filter capacitor or leaky diode in power supply.
Posted on Dec 22, 2006
SOURCE:
My 27inch Sanyo tv screen is shrinking-sides have curved black is=nstead of the full picture. Can you advise what this might be?
That is caused by an East West Modulator fault. That will give you an Hour Glass picture.
Check for dry joints around the line output stage and faulty driver transistors.
Hope this helps.
Dec 17, 2010 | Televison & Video
Hourglass picture. Panasonic CT-35G30T The picture is hour glassing from the sides. Starts to flicker back to normal after 1 to 2 hours. Getting progressively worse. Takes longer time to reach normal...
This is caused by bad solder connections in what's called the pincushion correction circuit. Some of the transistors get quite hot, and over time the solder connections to the TV circuit board become intermittent. When you tap the set, it causes them to make contact again so the picture is normal, but then it goes funny again. Resoldering the connections would take care of this problem. I would suggest calling a professional in to make the repair, which would cost far less than a replacement TV.
Hope this has been helpful, and thanks for using Fixya!
Feb 01, 2010 | Panasonic Televison & Video
Rear projection - convex distortion / ghosting / expanding screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Sony kp-61s70 hour glass shape on picture bows in
the sony service menu can be entered by pressing "display" "5" "vol+" also the diagnostic screen can be reached by vol- instead of + when you are in the service menu the number buttons navigate it its a little tricky at first but as long as you dont hit enter before you exit if you mess up it wont save just make sure if you fix it you save it by pressing enter
Jul 13, 2009 | Sony KP-61S70 61" Rear Projection...
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Picture get blurry on right hand side
if the convergence is also off suspect convergence ic problem
Nov 27, 2007 | Philips 43PP9202 43" Rear Projection...
Hour glass as picture
It is possible that your television needs to be degaussed. Gaussing occurs in televisions that have magnets, (usually speakers) placed to close to the unit. A degaussing coil can be purchased at a good electronic supply store. Simply follow the instructions that come with it. If this does not fix the problem, the television will require repair by a qualified service center.
Jul 25, 2007 | Samsung PCL541R 54" Rear Projection...
Televison & Video Logo
231 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
