Question about Air Tools & Compressors
My air compressor is running, but there is a little bit air
I have a 125 PSI Craftssman air compressor, which is 1HP / 12Gal, for one year. I used it for nailing the doors and windows molding last Summer, and I left it in my strorage. Yesterday, I used it to blow the dust that it still had about 40 PSI in the tank. I turned it on, and it ran okay. After 30 minutes later, I checked the pressure gauge, the pressure gauge hand still stayed the same pressure as it was( 40 PSI ). Then I let it run another hour, and I came to check it again. It's still the same result. There was no leak. Therefore, I would like to know what is wrong with my air compressor?
  • 1 more comment
  • rjake Nov 18, 2008
    I have a Craftsman 125psi/3 gal/1HP air compressor that builds pressure to 20 psi and no more. The oil is good, no obstructions and the motor keeps running. What can I do?
  • skajaquada Jan 19, 2009
    I also have a crafstman compressor, but 60 gal type. It will only pump 92 psi into tank. Just runs and runs, never building enough pressure to fill tank completly. Pulled pump apart. replacing gaskets. Rings and cylinder walls look perfect. No leaks anyplace. Any help out there?
  • Anonymous Mar 26, 2014
    I think I ran the rental compressor we have out of diesel gauge says it's low but it's on a bit of a slant. It is a caterpillar 375 cfm unit is there a primer and if so where would it be
    Scholar:
  • 65 Answers
Pistons may have lost their seals and not compressing the volume it needs. It's not turning off at 40 correct? That would be the pressure switch. Oil lubed probably like taking a small gas powered engine apart. Check the walls for scoring and such. If none to deep you can get an attachment for a drill to hone them. Auto parts will have that, parts depend on how old but should be at if you have like Sears Appliance repair stocks many different parts for what not. VERY expensive to let them do it but is an option for you. Make sure you have specs for torque and such for the bolts. And your sure no leak or pressure relief valve, yea you would hear that. I wish it was something else.But that's all I can think it would be if it's running continuously.
Posted on Nov 20, 2008
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
Hello , i found an awesome deal on the internet for an air compressor , its a briggs and stratton 15 gallon and it produces 4.2 cfm at 90 psi and 5.1 at 40 psi and it may run up to 125 psi. This is enought...
Too small,on CFM
If your spending less than $400 to 800,forget it
I had a Campbell Hausfeld for 30 years,with 20 gallon
I replaced it with an upright,30 gallon
I do not use an impact on wheel nuts,ever,and I use a torque wrench set at 80# going on.
That has worked for me,damage free for 35 years.
What kills the air,is the air chisel and worse,the cut off tool,which you will use the most.
Make sure what ever you get, uses oil,the oil less units last about 3 years.
Two stage is best,but I still have a single
Has to be wired for 220 volt,unless you like paying the electric bill
So hope you have circuit breaker and 1900 box branch circuit wiring experience
Forget the gas engine,unless your going on the road every week
You need about a steady 100# to really run any air tool--so that translates to about 10 CFM,little pricy
Oct 22, 2010 | Briggs & Stratton Air Tools & Compressors
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Compressor fills,drains off a little but won't
sounds like the pressure switch is fused shut, more than likely it needs to be replaced, most single stage pumps should shut off at 125 psi max.
Jan 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Why did my craftsman 5 hp 240 volt 125 psi air
your motor overheated from too low a voltage if theres a manual reset try this,also replace the two motor start and run capacitors on the motor body
Dec 24, 2009 | Air Tools & Compressors
Craftman 3gal/1hp air compressor runs normal, but
Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
Aug 09, 2009 | Air Tools & Compressors
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Oct 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
295 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
