Question about Sony WEGA KE-37XS910 37 in. HD-Ready Plasma Television
2004 sony wega 37'' plasma tv not turning on.
Ok so it turns on, the sound comes on, but the screen doesn't light up. the little sony light in the bottom middle comes on and then about 15-20 seconds later it goes back into standby. is it the plasma that has actually gone bad or are there video cards that go out on these tvs. ive been reading and appearantly this is a frequent problem. thanks a lot andrew
  • 4 more comments
  • candieandy Nov 18, 2008
    the tv powers up but theres no picture at all. when the input is on local tv coax. it makes the loud static sound until the tv recognizes that theres no input. then the sound goes silent. then the tv goes into standby mode.
    no the stand by light flashes red like it normally would.
    it flashes like it normally would.
    thanks a lot thats great
  • Any Guy
    Any Guy May 11, 2010
    So when the TV goes back into standby mode, the standby light does not flash?
  • Any Guy
    Does the standby light flash when the TV shuts down? If so, does it flash in a discernible pattern?
  • 320 Answers
You most likely have a power supply problem. but the problem may not be the actual power supply. The drive cicuits for the plasma panel can load down the power supply and give you the symptoms that you are having. Without being able to be there and take voltage measurements, I'm afraid I can't narrow it down more than that. My first suspect is that one or more of the sustain boards (the boards that drive the plasma panel) have failed. That would explain the lack of display. It is likely one of 3 boards that has failed, PSU (power supply) logic (the main control board for the set) or DE2 (panel drive board). There is a chance that the panel itself is bad, but that is not the most likely cause of your problem
Posted on Nov 18, 2008
  • Any Guy
    Any Guy Nov 18, 2008
    BTW my name is Andrew also and I hope I have answered your questions.
No sound or picture but lights come on sony wega plasma
Typical failure for all plasma tv's is a blown Y-sustain board. Another high failure for all tv's is dried out bulging capacitors in any of the power boards. You likely have one of these problems.
Mar 18, 2015 | Sony KDE-42XS955 42 in. Plasma HDTV
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega '
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
6 blinks
trying to locate you to ask you if you found out the problem to your sony ke37xs910 plasma 6 blinks. i have the same tv with the same problem. does your tv set have sound but no picture.
May 05, 2010 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Sony WEGA KE-42M1 sound but no picture.
i have the same problem! did you ever solve the issuE??
Oct 16, 2009 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Sony KV-27FS210 won't turn on: 5 blinks
If you have little experience of TV repair then take off back cover of Sony Kv-27FS210 and find Screen Control Knob on flyback transformer, turn that knob slightly CW or CCW and turn on TV to get picture. I think you need to turn ON TV few times to get proper adjustement of screen volts.
Above said procedure is for non-tech person.
(Tech person will adjust screen volts (G2) as per procedure mentioned in service manual with proper tools.)
Jul 28, 2009 | Sony FD Trinitron WEGA KV-27FS210 27" TV
This TV has a very expensive panel... we are talking $3000 core charge alone! It comes complete with all the lower buffer boards (which from the sound of it, you are having a problem with). Individual boards for this defect are not available on repair parts list I know of. A panel is what you need, PN: 9-885-063-33
Aug 17, 2008 | Sony WEGA KE-37XS910 37 in. HD-Ready...
32 inch sony wega
power board problem, needs to be repaired or replaced. Any TV tech can do this with the proper replacement parts. Common.
Mar 03, 2008 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Blinking STANDBY Light front of Television
Refere to Sony Blinking Codes :
5 Blinks ===> cause AKB circuit (AKB). Something is wrong with the video. check components on the C board, also check the A board. Also unit be in IK blanking, try turning up screen slightly.
Hope can solved the problem....
e-mail :
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA KE-37XS910 37 in. HD-Ready Plasma Television Logo
296 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
