Question about Nintendo Wii Console
No power won't turn on. tried varouis outlets. won't turn on to reset.
    President:
  • 4,402 Answers
Need new power supply
Posted on Nov 25, 2008
I’ve reset my hp laserjet p1102w but it still won’t recognize my new router%.
Try changing the router password and try again to link the printer. Obviously, you would have to go back and pair. (link) all other devices in the network using the new password.
Jul 24, 2018 | HP Office Equipment & Supplies
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
My belkin router wont light up?
  1. Try plugging the router to a different power outlet.
  2. Reset the router.
  3. Check the power adapter specification of your router and if you have another power adapter that has the same specification then try that power adapter to your router.
  4. If using another power adapter and your router will not power on still, it is possible that your router is faulty already.
Hope this helps!
Nov 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
