Question about JVC TH-M303 System
JVC TH-M303 I have a problem with the sound shutting off with the TH-M303 from JVC. If there is a "bang" or "boom" on a DVD or on TV it trips the breaker in the sub-woofer. The speakers are routed through the sub-woofer so they all go out, and you must turn them off then back on to reset the unit. This happens with any input (TV, DVD, cable). This happens at medium volums and is very bothersome in action movies where there is an explosion or gun shot. Even in such movies as "Harry Potter" when there is a sudden "Grroowwll" from a monster. Any suggestions?
  • rkean Dec 30, 2007
    While watching a DVD yesterday, the sound suddenly went out. It did not return after shutting down and restarting. I opened up both the DVD unit and the subwoofer unit and got as far as checking all the fuses. Is there a breaker reset somewhere or does it self-reset? Fuses were all OK - wondering if something got fried.
Well this is and isn't a fix. I don't know what the underlaying problem is that causes the Amp to shut down but I have come up with a way to stop it from doing so. What ever the problem is it is triggering a circut on the board called "Protect" which can be circumvented. You need to start by pulling out the amplifier unit from the subwoofer assembly. You will see that there are two circut boards at 90 degrees to each other that are connected by 3 sets of connectors. You need to remove the screws and wire that hold in the board attached to the bottom of the assembly. You can then pull it out disconnecting the connectors. The connector closest to the power trasformer is the one that we are concerned with. On the vertically oriented circut board you will find a small map of the connector identifying pin #5 as "Protect". Inside the portion of the connector attached to the bottom board that you pulled out, use a small set of needle nose pliers to break off pin #5. Then reassemble the amp and put the subwoofer back together. I used this solution and it has been working since. If you have reservations about breaking the pin out then try just bending it out of the way and partially reassembling the unit and powering it up. Once you see that it does indeed solve the problem you can break it out. Like I said, I don't know why it started to turn off spontaniously in the first place but this does fix the problem.
Posted on Sep 25, 2007
Th-m303 sub dont sound when playing dvd
Please try and connect the DVD using the coaxial or the optic cable so that the input is seperated to perrform on the amplifier with a true DTS.
Oct 26, 2011 | JVC TH-M303 System
I would like the owners manual for JVC 5-disc player TH - M303
You can download the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader
Thanks for using FixYa
Sep 26, 2010 | JVC TH-M303 System
Sounds cuts out if volume is over 30
hey
I have been has same problem for long time, actually problem was on and off... the reason was short circuit of speakers or speaker connections.
I find a little peace of cable stack inside of the connection handle. you know all the cable stick on back...
well what you can do is, unscrew all the screw back and the bottom of the box. slice the electronic box, just check connection piece is clean cable free....
use always clean cable and don't put it too much.
it is very easy to fix
http://www.myfixtips.com/blog/av-receiverhome-theatre/no-sound-from-jvc-th-m303-home-theatre-system-456.htm
Oct 11, 2009 | JVC TH-M303 System
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
Jvc th-m303 sub woofer not working all other speakers are fine
check your internal wires inside subwoofer.b4 that try to connect to other instrument to make sure it not working.
May 12, 2009 | JVC TH-M303 System
I can't seem to be able to get sound through the speakers when i am on cable tv. does anyone know how to fix this problem?
Run a set of phono cables from the tv audio out put to the aux in put on your system and set to prologic.
Hope this helps
CABLE GUY.
May 09, 2009 | JVC TH-M303 System
How to connect dvd to sub woofers
You need the sytem cable that goes with the system--see if your mate still has it 'cos they cost about £23 to replace
Jan 04, 2009 | JVC TH-M303 System
No sound
Look through the menus on the TV. There is probably a setting that allows you to turn them off and on.
Hope this helps, and please rate my advice, good OR bad.
Feb 01, 2008 | JVC TH-M303 System
No sound
please check cables between dvd and subwoofer.test with good new or working cables.
Jan 20, 2008 | JVC TH-M303 System
Subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Nov 24, 2007 | JVC TH-M505 System
JVC TH-M303 System Logo
245 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
