Question about Hunter 52" Ceiling Fan With Light And Remote Control
Remote stopped working
I have replaced the battery in remote but didn't help. neither the fan or light will work.The indicator light does light up on the remote when you try to use it
  • bill90803 Nov 30, 2008
    Light in fan wont turn on. Checked bulbs, batteries, code settings, all ok.
    Replaced remote receiving unit, same problem. Any ideas?
    Scholar:
  • 75 Answers
If it has a pull chain (many do, even with remotes) make sure it is not turned off there. If that is not the problem, make sure that the light is plugged into the harness in the box at the bottom of the fan. It is so easy to leave this unplugged, or forget to make the connection if it is not a modular plug.
Posted on Dec 21, 2008
I have a ceiling fan with a remote and the remote stopped working. The light blinks on the remote when I press the buttons, but the fan doesn't work. The model number of the
The light on the remote is just a battery indicator light. I would try changing the dip switches in the receiver & transmitter first. If that doesn't work, you probably need a new receiver. Good luck since this is a cheap store brand.
Oct 01, 2013 | Hampton Bay 24002 Ceiling Fan
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
Problem with hunter ceiling fan 23272
The problem is with the remote receiver attached to the fan body. It is a small device that acts as a remote switch and this is cradled in a pocket inside the ceiling fan itself. If you are handy, you can replace this device yourself. I believe you need to purchase a new kit from Lowes that comes with a matched transmitter and receiver for fan control. Go to Lowes Lighting section for this product.
Jan 12, 2018 | Hunter Dryers
My remote for sony dvd player NS 590 p suddenly stopped working. I repleced the batteries but it didn't help
if its not batteries it will be a replacement remote. try cleaning the terminals and see if helps,
Dec 10, 2011 | Televison & Video
The remote was dropped and now the fan does not work. It is not an easy task to get to the fan to replace since the ceiling is 18 ft high. We were sent a new remote and told it would work, but it does...
The remote has to be programmed to match the existing fan's receiver code. The programming information should have come with the hand held remote. If it didn't, contact whomever you purchased it from.
Jul 20, 2011 | Hunter Heating & Cooling
The remote for the fan quit working. New batteries didn't solve the problem. The are no strings to pull on/off, just a light switch which does turn on the light.
Just in case, I'll ask, Did you also change the remote receiver batteries, located behind the fan's cowling? If not, that should do the trick. Don't feel bad if you didn',most folks do remember they're there.
Jun 09, 2011 | Hunter Heating & Cooling
Kenmore remote control ceiling fan Model 689.116700 with variable breeze setting. Fan has always worked great but has stopped running and will not turn on. The simple things have been checked and the...
How about the remote can they be replaced? I just got the same fn from a friend that has been in box for 20yrs. All works fine but Im worried about remote going bad.
Jun 01, 2011 | Hunter 52" Ceiling Fan With Light And...
Remote stopped working, fan and light do not
click the reset and turn off the fuse box and then turn on
Feb 15, 2010 | Casablanca Fan 3245T Ceiling
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Dryers Logo
206 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
