Question about Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
Convection fan doesn't turn on
I've had my new Frigidaire, self cleaning gas range w/ convection oven for a week.(model# FGFL87GSF)....used regular bake successfully; tried to use convection option last night and although the display will show the fan icon spinning (as it's supposed to in convection, or "speed bake" mode) the fan inside the oven doesn't turn on, nor do I hear any motor sounds.
I called the service # on my manual and they asked me to trip the circuits of my house and then re-start the oven afterward.....I did.....same result: no fan. They gave me two "authorized" repair companies to call and one is out of my service area and will charge me to come out here (I just bought the oven on the 11th; I'm not willing to pay anything to fix my fan!) and the other is nearby but can't schedule me for 2 weeks. The oven works, just not the "speedbake/convection" mode and I'm wondering what could be wrong with it and if maybe anyone would have suggestions as to what I could try in the meantime. Or should I just leave it alone. Thanks!
  • tkhula Apr 20, 2009
    I have the same problem on that my oven it worked once!
    That's not making me happy. Should the fan come on immediately?
  • 3 Answers
Found this site cuz I had the same problem- as your purchase was 4 years ago- not sure that I'll help you... But help others who are stumped... I pushed the QuickBake button to preheat then to turn the fan on I pressed it again... ( actually a couple times messing with it...) Once it gave me a " double beep" and sometimes just a single beep but none the less, the fan turned ON!!! Good luck!
Posted on Jul 18, 2012
    Scholar:
  • 121 Answers
HI! kitmeow6
As this is a "warranty" Repair keep track of all conversations and make sure you get a case number from the manufacture. This can only be repaired by the "authorized" repair service representative. Make sure it is repaired within the warranty period or return the unit to the store where you purchased it. Sorry there is not quick fix for this one.
InMrFixIt
Posted on Nov 18, 2008
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Apr 13, 2013 | Frigidaire Gallery 30" Self-Cleaning...
How do i fix the light socket to my Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range
Hi michell51238 - From what you are describing it sounds like the range may possibly have a faulty light switch or wiring failure that only a professional can repair. I personally recommend consulting a certified technician for a proper diagnosis and to move forward accurately.
Feb 22, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Oven does not heat up
most likely you have a bad ignitor,if it glows and it doesn't ignite the flame within 40 seconds the ignitor is bad.just because it glows doesn't mean it's good.
Dec 12, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Frigidaire gallery convection fan doesn't work
Found this site cuz I had the same problem-didn't find an answer but messing around I figured it out... I pushed the QuickBake button to preheat then to turn the fan on I pressed it again... ( actually a couple times messing with it...) Once it gave me a " double beep" and sometimes just a single beep but none the less, the fan turned ON!!! Good luck!
Nov 07, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Frigidaire Gas Range with Convection--fan does not turn on
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
Dec 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Convection Oven Fan Failure
if the fan is cheaper you can replace it your self if it was making a noise id say thats where the trouble was
Jan 30, 2008 | KitchenAid KERA205P Electric Kitchen Range
Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
2,863 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
