Question about Insignia IS-DVD1001 DVD Recorder/VCR
Isignia DVD RW suddenly lost color. I now only see B&W
I've tried chaning cables, adjustments, etc. But still no color. I have a VCR hooked to the TV also, and it produces a color picture. I switched the DVD and VCR locations on the TV, yet the DVD still produces only B&W.
  • litochavez Dec 13, 2008
    After starting to play a DVD-R, a P-SCAN big display appeared in the screen and became double vision (2-half screen display.) I tried to reset it by holding the power button for 5 seconds, turning power off for 30 minutes and still the problem exists on different DVD format that I inserted. Do you have any idea to correct this problem? Your help will be greatly appreciated.
    New Friend:
  • 99 Answers
I think u are using the component out to view, right.
First of all see whether u can see a yellow color RCA jack labeled video out.
Try using tht output and post back
Posted on Nov 18, 2008
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
The buttons assigning DVD, TV, VCR, etc suddenly changed their assignments. DVD was now TV, VCR was now DVD, etc. I don't think it all happened at once either. Now I can't get sound from the...
There are facilities to CHOOSE the digital assignment. I've seen where extended power loss will randomly lose custom settings. Open the manual.
Jul 07, 2011 | Pioneer VSX-D912 Receiver
How to install samsung dvd-v1000 dvd/vcr combo ? I lost instructions and need to know what cords to hook up where ?
if your using rca cables then plug the coresponding colors from the out on the dvd to the input on the tv
Dec 21, 2010 | Samsung DVD-V1000 DVD Player/VCR
Dvd player /vcr dont have rf cable hook up
you need to go buy what they call a dvd modulator so you can connect using coax cable to the tv as long as the tv is cable ready they cost about $30.00 walmart , bestbuy etc
May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Color problem
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Can't get cable remote to operate GE 19TVR62
I found these remotes control VCR's only when programmed into the DVD button. It even says on page one of the manual that the DVD button is for DVD's, TV/VCR's, VCR's, etc. I got code 607 to control my GE VCR (using the DVD button). If that doesn't work, try 572 647 563 609 644 645 or 531.
Dec 11, 2007 | GE 19TVR62 19 in. TV/VCR Combo
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
Insignia IS-DVD1001 DVD Recorder/VCR Logo
124 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
