Question about Logitech Harmony 890 LCD Remote Control
Charger Base Doesn't Charge
Can you give me a tip on the charger base? My charger base is no longer working. The blue light is on in the base but it does not charge the remote. I have had the remote for 11 months but only started using the remote about a month ago. Is there something I can do and if not is this covered under the one year warranty? Thank You
  • 4 more comments
  • Anonymous Jan 03, 2009
    I also have this same problem that my base will not charge. I got new battery and the base charger does not appear to charge the battery. I now have two batteries, does not appear to be the battery. I check the voltage it is around 8.x volts coming from the plug in power supply, an the between two of the outer 3 pins I see 8.x volts so, not sure what is going on.
    I also have this problem, tried replacing the battery same problem after ~ $35, check voltage of plug in ~ 8.x volts and the there is voltage on the two outer pins of the 3 gold base pins....whats up?
  • fishheadhunt Jan 03, 2009
    I have the same problem.
    Replace battery same problem.
    Check voltage, looks ok at ~ 8.x volts.
    Not sure the problem...
    Help..
  • Anonymous Jan 18, 2009
    i have the same problem. remote is 1.5 yrs old, and does not get that much use. the contacts seem to be worn a bit on the remote. i have seen other posts on the web indicating that logitech has had problems with the base.
  • ashton3 Jan 18, 2009
    Same problem. Based charger simply does not make proper contact with the remote to properly charge. It definitely is a design flaw and Logitech needs to address this, especially given the price point of my 890 remote.
  • 3x1-2 May 16, 2009
    I have the same problem and also bought a new battery (to no avail).  I do not think that it is the connections as I have found that sometimes unplugging the charger while the remote is on it jumpstarts the charging (but you then need to reconnect the RF extender).  It also sometimes works when I take the battery out and then put it back in and put it on the charger (these solutions are now getting less and less effective), which also requires a reconnecting to the RF extender.  Based on this, I am thinking that it either the base or the remote failing to recognize the other.  I noticed it happening about a year or so after using the remote (I have had the remote for well over 2 years now).
    I wonder if there is a way to charge the remote through the USB connection (like you would do for a blackberry).  Has anyone tried that?
I just had the same problem, went to best buy and got a new 890 and tested the old remote with the new charger, the new charger has a different design slightly, has only two pins and no center pin on the charger. its charging the old remote now so its definitely a design flaw. Not sure what to do now tho.
Posted on Jun 16, 2009
The back unit of charger will not charge radio?
common. The contacts are dirty most likely. Unplug the charger, get a small piece of fine or extra fine sandpaper and lightly sand the metal wires you see. They will bend, that is normal. So, slow and careful. Still not working? (also common). The charger base or the charger AC adapter may be bad. If you have another charger, switch the wall adapters. If the base if base, you could try to take it apart and re soldier it yourself, but if it got wet, the game is over. Go to a used donation place, such as the Goodwill to get replacements. They are not sold new without a radio. Also, try another radio in the "bad" charger, it could be the contacts on the back of the radio need cleaning.
Feb 17, 2016 | Motorola MH230R Two Way Radio
Harmony 890 remote: Where can I buy a new base charger for the remote? The adapter feeds it power, and there is a new battrey in the remote... but the base is NOT making contact with the remote.
Befor buying a new base, try cleaning the contacts with isoproply or rubbing alchol and use a q-tip, besure to clean both sides, the base and the remote.
Good Luck
Let me know if this works
Jul 01, 2008 | Televison & Video
On the wahl 8779 does the blue charge light go out when full charged
Yes, the blue light goes out when fully charged. It should come on for at least a few seconds when it is returned to the charger base.
Jun 19, 2014 | Wahl 8779 Sterling Mag
I have a pair that takes batteries an a charger base charger how does this work
They are often fitted with rechargable AAA cells. These can be charged by putting the phone on the charger base. Obviously the base must be plugged into power. You could alternatively take the rechargable cells out and charge them in a standard charger. The radios will also work with non-rechargable batteries but don't try and charge them or use the charging base.
Oct 29, 2013 | Radio Communications
Kx-TY4500 charger will no longer charge handset
could be one of two things
1.battery defective
2.already charged
sometimes if the battery wont charge any more if could be due to
overcharging. try checking all the connection ports
Oct 03, 2012 | Panasonic KX-TG4500 Phone
Why did my Panasonic phone quit charging in base unit?
Check the condition of the charge contact tips in the phone cradle, there are uaually two or three spring loaded pins that contact the phone charge contacts. Make sure these are clean and the springs still work. If these are good, you can check the output of the charger with a volt meter at the spring loaded pins, you can get the correct voltage off of one of the satellite units and compare it to the base. If the base is not putting out the same voltage the charger has likely failed.
Feb 27, 2012 | Panasonic Lands Phones
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
Logitech harmony does not charge
Mine does that on occasion. Is the blue light on in the charger base? If yes, check the connections on the charger base and the back of the remote to be certain they are clean. Does the remote do anything when you place it in the charger? If no to the blue light or the response of the remote, be certain the wall outlet is working, test the wall adapter, test the charger base. A voltmeter is handy for this. The only way to determine where your problem is, is to check to be certain all connections and pieces are doing their jobs. Test one at a time, divide and conquer. I hope this gives you some hints that lead you to a solution to your problem.
Nov 16, 2009 | Logitech Harmony 880 LCD Remote Control
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Logitech Harmony 890 LCD Remote Control Logo
728 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
