Baby Gear Logo
Posted on Apr 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i attach the wind shield onto my quinny buzz 3
Dorel UK
Level 3:
  • Quinny Master 1,637 Answers
  • Posted on Mar 09, 2013
Dorel UK
Quinny Master
Level 3:
Answers
1637
Questions
0
Helped
453531
Points
2410
Hi
The windstoppers zip onto the sun canopy of the Quinny Buzz pre-2010 model.
The post-2010 model Quinny Buzz is not compatible with the windstoppers or mosquito net.
5 Related Answers
Anonymous
  • Posted on Feb 18, 2009
SOURCE: Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
Anonymous
  • Posted on Mar 14, 2009
SOURCE: Turning Quinny Buzz 3 into buzz 4
I bought it and its great - much easier to push
Anonymous
  • 419 Answers
  • Posted on Oct 11, 2009
SOURCE: problem with the front wheel Quinny buzz 3
This does sound like you have got a build up of dirt within the wheel assembly unit. I would suggest that you remove the entire wheel (push the two black buttons either side of the axle and pull) then clean the entire wheel in warm water. Lubricate the moving parts with a thick lubricant (something like vaseline, not DW40 as this attracts dust) then pop it back on, that should sort it out.
If the wheel is still not working, then contact your retailier if still within warranty (two years chassis and one year fabrics). If this is out of warranty, contact www.quinny.com who will be able to sell you a replacement wheel assembly.
I hope this helps.
Testimonial: "Thanks for your help, he will is much better"
dutchtexan
  • 60 Answers
  • Posted on Nov 06, 2009
SOURCE: One of my Quinny Buzz Tires are flat. It is
You need to either have a new inner tube put in it or you can try adding a flat repair gel in the tube to fix the leak. You can get what they call "Green Slime" their are other brands also available under different names but this is most common. It can be purchased at Walmart, Home Depot, Ace Hardware and Auto Parts Stores. This is easy to pump into the tube valve stem without removing the tube or wheel and should fix any holes or leaks on it. Then just pump it up and you should be ready to go.
Hopes this was helpful, DutchTexan
Anonymous
  • Posted on Nov 26, 2009
SOURCE: I can't attach the footmuff to my quinny buzz
Took me a while too.
You can up-pop the shoulder pads and the straps themselves undo (like a slotty slidey thingy) and you can thread them through and then reclip.
Hope this helps!
Jodie
How do you attach the windshield to the quinny buzz 3?
Hi
If you have a pre-2010 model Quinny Buzz you will have a zip around the inside of the hood which the wind stoppers zip onto.
If your Quinny Buzz is post 2010 model it is not compatible with the wind stoppers or the mosquito net.
3helpful
I have a quinny buzz 2005 frame will a replacement seat unit fit this and will the carry cot fit please
Good Afternoon
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
I have a Quinny Dreami Bassinet - Gold...the description says the Buzz 3 stroller still folds with the bassinet attached but I can't seem to do this...can anyone help?
hi
i'm not sure you can fold the buzz with dreami still attached
here are upto date instructions for the dreami
http://www.quinny.com/media/producthandleidingen/Quinny/2009%20Manual%20Buzz%20Dreami%20UK.pdf
for the buzz
http://www.quinny.com/media/producthandleidingen/Quinny/2009%20Manual%20Buzz%203%20UK.pdf
after reading them i would say it has to be removed(I only had the pushchair)
I need instructions for a quinny buzz, dreemi, travel system. I don't know how to attach the different seats, travel cot etc
The Dreami Carrycot will attach using the adapters which usually come inside the Buzz Box (Black bag that is clipped onto the back of the chassis). These adapters also are to be used to attach the Cabrio Carseat.
Alternatively, you can visit www.quinny.com where you find the user manual.
I hope this helps.
Should the carry cot piece have the two metal parts on it to clip into the frame of the pram?
Good Afternoon
The Quinny Dreami pram body attaches onto the Quinny Buzz chassis using the two plastic adaptors included with the Quinny Buzz purchase. Replacement adaptors can be ordered via your Quinny retailer.
1helpful
Maxi cosi installation on a quinny buzz 3 -how does it work?
I assume that you refer to the Maxi Cosi Cabrio onto the Buzz chassis? When you purchase the Buzz, along with other extras, you will receive the Cabrio Adapters. These are clicked onto the chassis (this is in a hole where the seat unit would be if using that component) These adapters allow you to also click the carrycot onto the chassis.
It you visit http://www.quinny.com/quinny/instructions.aspx?id=3 you can watch a demo movie which will explain this to you. I would strongly urge you to visit a good nursery retailer who should be more than happy to take you through the process.
I hope this helps.
I have a quinny buzz and the catch that keeps the frame shut is not working, so when driing it can pop up! I brought this second hand so no idea what to do.
If this is a first generation Buzz, you should be able to get the nylon clip style catch that attaches onto the frame and keeps it closed. I would suggest that you contact http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=gb-en as they will be able to assist with this.
I hope this helps.
Can't tell if my Quinny Buzz 3 is suitable for my baby
check out http://www.quinny.com/quinny/default.aspx?language=ch-en
The moulded seat is intended from 6 months. From birth it is recommended with the Maxi-cosi car seat.
3answers
Quinny buzz, dont know how to attach the carrier bag
If you are talking about the quinny 'buzz box' bag, then it clips on underneath the seat chassis where the back wheels are. On the back of the frame you will see to litttle catches sticking out, one on either side, and the buzz bag hooks onto these.
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
