Question about Moultrie MFH-DGS-100 Digital Camera
Mfh-dgw ''card locked' displays on screen
When I insert the 2gb memory card, the screen reads " card locked". The card will not work. The card is good. It works in my other camera. Any help outhere? thanks
  • LIDG Nov 21, 2008
    Same problem here. It worked fine for the first 6 weeks I had it now, it says SD Card Locked---what's going on?
    Top Expert:
  • Moultrie Master
  • 49,159 Answers
Take the card out and side the lock to the unlock position .
Posted on Nov 20, 2015
SOURCE: moultrie mfh-dgw
i can not access pics or videos on the camera when i do not use sd card?
Posted on Jan 19, 2008
SOURCE: moultrie MFH-DGW 2.1
i need the operating directions for theMFH-DGW 2.1.
Posted on Oct 22, 2008
  • 231 Answers
SOURCE: Request for Operator's Manual
All the Moultrie camera manuals available via PDF =>
If not listed, try calling them (800) 653-3334 or (205) 664-6700 Monday through Friday 8am to 5pm Central Standard time.
Posted on Dec 27, 2008
  • 296 Answers
SOURCE: Where can I find parts for a Moultrie Camera
Depends on the parts...An operator (user) manual can be download/printed (PDF) from
Posted on Feb 17, 2010
  • 12 Answers
SOURCE: Moultrie camera mfh-dgw 2.1 reads BATTERY LOW but
depleted batteries,buy new rechargable ones
Posted on Feb 28, 2010
Moultrie camera mfh-dgw 2.1 buttons stopped working and reads no battery power with a new battery. Then Poof it shows full battery and then buttons work, then poof battery level shows nothing buttons don't...
Although I am not totally familiar with the camera, I would try a reset. This worked OK for the Canon I got. Like, remove the memory back-up battery, wait for 30 seconds or so and put it back in. This should do a complete reset. There is also the possibility that the back-up battery needs replacing, that could give the same problems. Good Luck.
Sep 25, 2013 | Moultrie MFH-DGS-100 Digital Camera
Reading memory card
Try using another memory card, this time of less capacity i.e if you were using say a 8GB SD card, try a 4GB or 2GB one. It could be your phones not compatible with the cards storage capacity.
Hope it helps.Thank you.
Jul 14, 2012 | Samsung Cell Phones
Are you using an adapter for the memory card?
The adapter will have a lock in the indicated place. Use it to unlock.
If you are not using an adapter, you might have used some software to lock it. If you don't remember, you may have to format it first. But by formatting, you will loose everything in the memory card!
Jul 19, 2011 | SanDisk 2GB microSD Memory Card
Operating instructions for Moultrie model MFH-DGW 2.1
Moultrie DGW-MFH 2.1 megapixel instruction manual - Archery Talk > ... > Game Cameras
Jul 2, 2010 - Have my first game camera, I believe it is the DGW-MFH 2.1 megapixel and ny son lost the instruction manual. ... Then it would be the model MFH-DGS-100V2; it's a 2.1 mp camera. ... Says I'm forbidden to see the link to what the camera looks like but the owners manual I downloaded and it ...
Operating instructions for Moultrie model MFH-DGW 2.1 ...
Aug 15, 2010 - i can not access pics or videos on the camera when i do not use sd card ... i need the operating directions for theMFH-DGW 2.1 ...
Aug 15, 2010 | Cameras
never had much luck with 6v lantern bats...drain too fast.Moultrie estimates 20 day life...less if you're getting a lot of events...I recommend the "equivelent"..6v, 4AH or higher rating...
The SD card may be "locked". Check that small switch on side of card is pushed toward contact strips.
Jan 18, 2010 | Moultrie MFH-DGS-100 Digital Camera
How do i get the memory off my cam I didnt have
it should have a switch to enter setup, and up/down should be able to find a menu item that reads "delete all;toggle to yes and select...wait...done...go back to main setup've done it!
Oct 04, 2009 | Moultrie MFH-DGS-100 Digital Camera
Moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
Apr 11, 2009 | Moultrie MFH-DGS-100 Digital Camera
Locked up
On my Moultrie MFG-DGW 2.1, I was unable to change settings etc... It seemed to be locked at the Date/Time screen. I powered off the unit, removed the memory card. Turned on the unit. Then I could change the settings. I made my changes, powered the unit off, reinserted the memory card, turned the unit back on and it read the card and I could make changes too. This happens from time to time. I just have to follow those steps to clear it.
Hope that helps.
Oct 28, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Oct 05, 2008 | Moultrie MFH-DGS-200 Digital Camera
Moultrie MFH-DGS-100 Digital Camera Logo
159 people viewed this question
Top Moultrie Cameras Experts
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
