Print error get a print error 51 When I called Tech help I was told it could be "mechanical and is just out of warranrty. It worked fine until I used a very "thin" paper--kind of like typing paper in the "old days". I printes a couple things and then the error message came up and it hasn't worked since. any ideas?
  • hickssix Nov 18, 2008
    did all that. no luck
    did it. no luck
    President:
  • 2,712 Answers
Use different paper and make sure you select the correct paper type in printer properties. Then unplug the printer for 5 minutes from power source and replug.
If this does not help, please post back with more details like any error messages, make and model of printer, your OS, etc.
Posted on Nov 18, 2008
    Genius:
  • 1,913 Answers
Remove your cartdgwe thwen powr up.
check there is not any paer jam.
HP C7280 ink system failure error: 0xc18a0101
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
I hope this help those who have similar issues
Jun 16, 2011 | HP Photosmart C7280 Printer
What would cause vertical "squiggles" until unit warms up?
This set uses what is called a "Hyper" board; it processes all signal from all inputs.
These sets have a history of tiny capacitors on that board failing, called surface mounted that dry out and fail.
The classic pattern when this problem happens is the period until it clears up gradually gets longer and longer.
The board is no longer available and only available if removed and sent out for repair.
Probably not worth doing as the last one I saw cost over 200 for a repair/rebuild.
I do not like giving bad news but this is what you have.
If this information told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 31, 2010 | Toshiba 51H93 51" Rear Projection HDTV
I have error code 51 and 21 on the printer. I
21 is "Page too complex"
51 is "Beam detect error" or "laser error"
My question to you is, does this only happen when you are printing a page that is very graphics intensive, or does it happen with simple jobs too? It could be that you just don't have enough memory in the printer to handle some of these pages. Then again, you may have to replace the laser scanner. I advise you to call a tech out to take a look at it rather than trying to fix this on your own.
If it isn't happening too often I'd probably just **** it up and live with it if it were me. If it is getting in the way of business though you really ought to call a tech. A lot of times these things can be fixed for a lot less $ than you'd think.
Dec 22, 2009 | HP LaserJet 4700 Printer
Exact same problem as OP
Canon support was able to help me with this issue.
First, scanning with the MF Toolbox is only supported via USB, not across the network (scanning across the network generally does work but you need another application that supports it). Second, you must make sure that you have switched the device into USB scan mode. Press the Scan button on the device. If the display says "Network scanning" press it again until it says USB Scanning. From then on, scanning works beautifully.
Aug 22, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Replaced printhead and ink cartiages on a Kodak ESP.3
I had my esp3 stop printing black also. I bought new cartridges even tho' I knew the ones in the printer were at least half full. Still not printing black. I finally called Kodak support and got a tech who was the first tech from India who could speak English well. He was very helpfull but in the end he told me he would send me the printer head because that was the problem. My printer was not used for about a month and the head dried up. The tech said that printer must be used about twice a week and the best way was to print the test by using the 'Scan' and 'Copy' at the same time. There was no sense telling the tech this is a huge flaw in the printer as he must have been hearing this for a long time. After I received the new printer head it prints fine. This is an absolutely huge flaw in this printer. If they can't make a different style of head for this printer these will stop being used................. So if you have the ESP3 (I don't know about the other models) and don't use it often the head will dry up and you can't clean it (according to the tech I talked to). Kodak should send these free for the life of the machine in my opinion.
May 02, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
MFC 210c Unable to Print Use Troubleshouting and routine maintenance chapter in Users Manual
My color has not worked well in the past few months. Now I get the message Unable to Print, Use Troubleshooting and rountine maintenance chapter in user's manual. I've tried everything it told me. I've removed all ink cartridges and left them upright (they are ALL brand new) and cleaned all the ink ports. I've cleaned the machine several times. It's told me there's no ink cartrige, I've replaced them, turned the machine off and on, unlplugged, etc. Then go to print and I get the same message again and it won't print. The machine is almost 2 years old and has worked fine until about 6 months ago when the magenta stopped working all together. Now this. Any help? Thanks.
Nov 05, 2008 | Brother MFC 210C All-In-One InkJet Printer
Error Message C-2253
C2253: Color PC Drum Motor’s failure to turn
try to turn these IU's manually, and reset the error, sometimes helps, because usually motors works fine. also you may try to change IUs
Oct 29, 2008 | Konica Minolta bizhub C250 All-In-One...
Printer Cartridge problem
No, I haven't solved the problem. That's why I hoped that someone else had, and might be willing to share.
Oct 02, 2008 | Brother Multi-Function Center MFC-3360c...
Rundll32 Error
copy rundll32 from someother vista laptop and replace yours.
May 24, 2008 | Computers & Internet
k24674
jasbo
jasbo
