Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi 1080P has tiny black & White dots flashing on screen
Dots just started on Saturday, on all channels. Cable provider claims they cannot help.
nahokuiiwebg
SOURCE: 52 mitsubishi has small white dots of light that dont go away on most of the screen
Mitsubishi is replacing these DMD IC chips nationwide under an unannounced kind of recall for model #'s WD60C9, WD73733, WD57734, WDY657, WD73734, WD65735, WD60735, WD65C9, WD73840, WD65833, WD65733, WD73735, WD73833, WD57733, WD65734 and others. Call them @ 800-332-2119 and give them your model, serial # and date of purchase, tell them you have the white spots, they will set up a workorder with a local Mitsubishi servicer to come to your home and replace the DMD chip. Mitsubishi will supply the part (part # 276P595010) for free, but you must pay $200 in labor. BUT...if you ask for Shantell Hebert when you call Mitsubishi, and really push the issue, she will also pay half of the $200 labor fee, so you go from $400 to repair to only $100. Once that chip is replaced, the unit works great again!!
Posted on Aug 27, 2012
SOURCE: White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Posted on Apr 25, 2012
  • 192 Answers
SOURCE: Tiny blue dots and ablue cloud at the bottom
There is a possibility that the symptoms that you described is covered under an additional warranty, even if your set has been out of warranty for years. Sony has a site that describes this repair at no cost to the consumer: http://esupport.sony.com/perl/news-item.pl?news_id=127&mdl=KF50WE610 If this is not covered, then, the blue light panel is going out and that means it needs a light engine. Good Luck
Posted on May 13, 2007
  • 441 Answers
SOURCE: Small white dots are showing up on the screen when
The white spots you are seeing are a result of dust or dirt in the light asm. Mits knows about this as a problem. The inside chamber of the tv needs to be cleaned. If your tv is in warranty they will come to your home and fix it. If not it is very easy to damage the tv by trying yourself, start with cleaning out the chamber that the bulb is in, use compressed air to blow out dust and dirt, them on the sides of the tv are round flaps that will need to be removed and this will go into the main mirror chamber, be careful but blow out any dust or dirt you see on the mirror. I would have a repair tech handel this unless you are skilled in this area.
good luck
Posted on Nov 13, 2010
  • 597 Answers
SOURCE: I have White and black
I developed white spots on the screen of my Mitsubishi WD-57734 in increasing numbers over days and weeks. I called a repair service who quoted me $1500 to replace the light engine. He suggested I call Mitsubishi Customer relations at 800-332-2119 option 5 which i did. To make a long story short after several conversations with them they agreed to replace the part for free if I picked up the labor (Would have been less conversations if I had the original purchase receipt). Instead of $1500 I paid $250. The tv was only 3.5 years old. Perseverance paid off.
Posted on Jun 17, 2011
I do I fix white dots on screen
Hi
Have you tuned the channel frequency tuner? Use the remote to bring up setup menu on TV, scan channel frequencies & save. If it's an old TV that can't pick up digital signals, then you need to get a digital set top box & tune to TV.
Jun 26, 2014 | Mitsubishi WD-65735 Television
Dots
Sounds like DLP fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 19, 2014 | Mitsubishi Televison & Video
ScreenWhite Dots on
Common problem ---http://www.tomsguide.com/forum/57674-4-white-dots-mitsubishi-screen
Feb 26, 2014 | Mitsubishi Wd-73733 73-inch 1080p Dlp Hdtv
Little white dots in tv modle# wdt657 what are they how can i get them off
Your TV is DLP projection TV. DLP is Digital Light Processing. Digitally processed light coming out of DMD (Digital Micro mirror Device) is projected on the TV screen. This DMD is made of thousands of tiny mirrors & the size is about 0.7 inch. These mirrors are fixed with tiny hinges for its movement. They reflect light as per processed signal. DLP is invented by Texas Instruments. When there are dots on the screen, that means the tiny mirrors representing the dots are stuck in its position. If the dots are few & the viewing is bearable, just leave as it is. If the dots are more than bearable then you will have replace the DMD chip which is quite costly.
Sep 25, 2011 | Mitsubishi WD-Y657 65" HDTV
What Causes the white dots on a DLP Mitsubishi tv?
the white dots (sometimes you get black ones too) are caused by a faulty DLP chip. you can find the replacement for your TV at the following website:
http://www.shopjimmy.com/dlp-chips/
Mar 20, 2010 | Mitsubishi WD-60735 Projection Television
Developing white dots
white Dots appearing on Mitsubishi DLP 1080p. What causes this?
Jul 15, 2009 | Mitsubishi WD-60735 Projection Television
There are tiny black dots on my LG Vantage screen
I have the same thing too. My guess is that some of your MEGApixels (tiny squares that create your screen) Are fried.
Mar 30, 2009 | Cell Phones
White dots across the screen
It is a timing problem with the cable, you will only get it on 1080p. Is your cable particularly long, or are you using an adaptor (2 x Cat5e network cables)? Try a different cable.
Jan 19, 2009 | Sony BDP-S350 Blu-Ray Player
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
613 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
