Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
Memory card is write protected ????
How do I unlock this feature ???
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Apr 29, 2012
SOURCE:
I cant format my microsd because of write sector error
hi
make sure your card reader is not locked. Most card readers have facilities to lock a memory stick. If left in that position, they write protect the memory stick. Meaning you can neither transfer to it nor change and sometimes remove stuffs from the memory stick. Insert the memory stick into another card reader and try formating again or check the memory card itself if the write protect feature is part of its structure. Usually there's a hint of that in form of tiny diagrams and signs of how to lock and unlock the memory stick. hope this helps
Jul 04, 2011 | Computers & Internet
My camcorder won't record. The memory card icon on the screen shows a lock on it as though it's protected so the camera won't record while in a bag etc. How do I turn that feature off so that I can...
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 13, 2011 | Aiptek IS-DV2.4 Camcorder
How to remove protected feature
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 22, 2011 | Samsung Digimax A503 Digital Camera
CAMERA SAYS CARD IS LOCKED ON A SAMSUNG P1000 CAMERA
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
If it is not that, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Have you tried formatting the card in the camera? This would be one way of making sure that the camera can cope with the card, and it will also erase anything on the card.
Jan 03, 2011 | Cameras
Card locked how to unlock
Jan 03, 2011 | HP Photosmart M547 Digital Camera
Whenever i turn on the cam, it says that the memory is locked
Nov 30, 2010 | Sony Cyber-shot DSC-W130 Digital Camera
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
Oct 12, 2010 | PNY 2GB microSD Memory Card
How do i unlock my memory card it is protected
See the video below This helps to remove the protection from memory card
http://www.youtube.com/watch#!v=Be_aHSlDFCU&feature=related
Thank You
Oct 12, 2010 | Cameras
I hv a nokia 7210 cellphone. bt the 1 gb memory card becomes password protected. how i can open it?
I suppose you didnt insert any password to your memory card.If you didnot put password then you can unlock the memory card by seeing the below youtube video
Thank You
Aug 11, 2010 | Nokia 7210
Memory Card is write protected
Does your MMC have a Lock/Unlock swap features? if it does. Then Unlock it. Or, you might want to format it.
Jun 14, 2009 | Nikon COOLPIX S51 Digital Camera
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
59 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
