Question about Miele 24 in. G865 Built-in Dishwasher
Dishwasher not washing
I have a Miele G865 and when I start it you can hear the water going in to the machine and the unit will go through the whole cycle and at the end it will drain the water but nothing happens in between. The dishes are still dirty and the soap is still in the dispenser with the door shut.
Check the very bottom tray under the machine. Remove the lower front cover, 2 screws, and you'll find a tray full of water.  A Turkey Baster will **** most of it out,  towel the rest.
Once dry, the machine will operate through all cycles, most likely.
This is a common problem with this model.  I have to do this about once a year.
Posted on Jan 07, 2009
  • Mike Martin Sep 10, 2012
    I removed the front cover, but I don't see a tray of water. It appears the tray is attached to bottom of DW. How do I remove tray?
Thanks a lot... it solved my problem...
Posted on Feb 08, 2010
A small amount of water (less than an inch) remains at the bottom of my G865 dishwasher. What should i do to fix this problem.
Hi
you have a partial blockage on your outlet. I would say the pump has something small jammed in it. Pull out your filters and There should be a clip over a plastic chamber. Slide across th clip and remove cover. Check inside and see if anything is caught in the pump chamber and remove it. Once cleared put it back together and it should work. Good luck. and make sure people rinse their plates before putting them in the washer. A lot cheaper than a $200 service bill.
Jan 07, 2011 | Miele 24 in. G865 Built-in Dishwasher
Miel dishwasher G865 Was not cleaning dishes properly so I put some Power 1 which is similer to CLR, started a wash cycle then partly into it I switch it to rinse. Now it still the same and the water...
Sorry to read about your problem, I hope this helps you out.
you may have a clogged pump, or a defective pump.
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Miele 24 in. G865 Built-in Dishwasher
F14 code Miele Dishwasher
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Aug 14, 2010 | Miele Premier-Plus Built-in Dishwasher
Our Miele DW just keeps going through cycles constantly and will not shut off on its own. It has gone all day. When we turned the dial manually to "OFF", the water keeps filling until it overflows the...
hi,
sounds like a faulty electronic unit as i have seen this before where the unit continously fills with water.
you will probably need a service call to repair the unit unless you are happy to fix it yourselves. have a chat with Miele directly as they are very helpful
Hope this helps.
Jun 20, 2010 | Miele 24 in. G865 Built-in Dishwasher
No water is going through the hot water connection device to the washer, why?
It's either not getting the signal from the temp selector switch or the valve is not working. You can swap the hot and cold to see which it is.
May 20, 2010 | Miele 24 in. G865 Built-in Dishwasher
G865 - Constantly draining
Your problem is a water leak.  There are a couple of rubber seals that are required to correct the problem.. When the seal leaks it accumulates in a tray in the bottom where a sensor turns on the pump when water is present.  If you remove the lower access panel and reach in you should see the accumulated water.  I had a repair tech repair mine.
Aug 20, 2008 | Miele 24 in. G865 Built-in Dishwasher
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Miele dishwasher film and crust on the inside-
Hard water has this "crust" which are minerals floating around that ionically attach to everything. Some machines from Miele have a water softener inside the machine. Special dishwasher softener Salt is added that cleans minerals off Xeolite beads. When cleaned they attract mineral ions. If you don't use the salt then the beads fill up on minerals until they can't hold any more minerals. The salt is used in the regeneration cycle. It washes the mineral ions off the xeloite replacing them with salt ions. As new water enters the machine mineral ions slowly knock off the salt ions and attach themselves to the beads again. This whole process keeps the crust off the dishes and the walls of the machine.
Use a dishwasher cleaner that removes scale. And if you don't have a salt light on your Miele you can instead purchase soap tablets that contain water softener built in. Miele dishwasher tablets have it. You can order them online or call Miele.
Dec 17, 2007 | Miele 23 in. Novotronic G841 Built-In...
Intake/Drain Error
There is water collected in the inner tray of your unit. Pull out the Miele and take off the drain hose and unplug the unit. Then tilt the dishwasher back 60* and let it drain out all the water. There will be a couple of cups on the floor, but nothing too big that a couple of towles can't handle. Then reconnect everything and start up the unit. It WILL work! It just happened to me and my Miele incognito is now working like a champ again!!
May 21, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele 24 in. G865 Built-in Dishwasher Logo
457 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
