Question about Casio Sea Pathfinder SPS2011V Wrist Watch
Press Buttons Hi, I have a watch and when I press the 'Mode' button, nothing happens.... also, when i press the light button, nothing happens... the light doesn't even turn on... Can you help me please... Thankyou
2 Suggested Answers
  • 2334 Answers
SOURCE: How to stop a casio watch from beeping when i press the buttons
Check watch caceback. All numers are there. Upload the numbers here and then we can help.
Use an eyeglass if numbers are too small.
Posted on Dec 21, 2008
  • 10 Answers
SOURCE: I have a casio sps-300
Hi I am a watchmaker and this is a common problem that i have found a lot of times. The watch needs to be opened up and shorted out. With a pair of thweezers touch the AC & the - and this should solve your problem.
Posted on Jul 24, 2010
0 characters
1 Points
My wife has a Nike Alpha Project watch with new battery. We cannot set the time. I press "Mode" and nothing happens. I hold it down and nothing happens. Perhaps the buttons do not work? Shawn
Maybe the button is not pushing the internal button properly. Undo the back and remove the watch unit from it's case and then see if it works when you press the internal button.
Aug 02, 2010 | Watches
How to set the time on a breo watch?
Received my Breo watch in the post today, and i thought it would be simple enough to change the settings...however when i press the A and M button on the back nothing happens, i've pressing it lightly and with more pressure but to no avail. the manual just says to press it, so am i doing something wrong?
Jul 02, 2010 | Watches
I am trying to set a digital watch, there are 4 buttons 1=light 2=mode 3=start&stop 4=lap reset. I can not find the name brand and I bought it at a second hand store for my grandson. The only name I...
mcdevito75here, I'm sue I can help you set this digital watch,----4 buttons, 1=light, this should be just for the light built into the watch, 2=MODE this is the button you press to set the functions, press this button and see everything flashing 3= Start Stop this button should act as set after you press MODE it should also be to start the lap counter and 4= lap reset this should bring the lap counter back to zero or the seconds tick normally.---- press MODE see everything flashing, then press start stop to set functions, hour, minute etc, press MODE after you have set each function, hour, minute, etc. When done with all functions press mode again to bring the watch back to normal operation.
Jun 23, 2010 | Watches
How do i change the time on my polar f6 watch
If you start from the Time of Day display, repeat steps 1-3, page 38.
4. Press the / buttons to select TIME. Press OK.
5. Press the / buttons to select 12 H or 24 H time mode. Press OK.
If you chose 12 h mode, select AM or PM with the / buttons. Press OK.
6. Set the hours with the / buttons. Press OK.
7. Set the minutes with the / buttons. Press OK.
Nov 25, 2009 | Polar F6 Wrist Watch
Digital umbro watch purchased 2001.How to change time please. 2 buttons on left. top light, bottom mode. 2 on right, top st/stp, bottom reset.
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Oct 06, 2009 | Bulova Watch
I can change everything but the date. How can I change just the date on my watch. The model I have has 4 buttons (Mode, St/Stop, Set, and Light). Can someone tell me how to change nothing but the date?...
Hi 1234910,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Jul 16, 2009 | Timex 1440 Nylon watch
Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Oct 21, 2008 | Casio Watches
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Casio Illuminator w-94h
Hold down the "Adjust" button (top left) for three seconds. It won't adjust unless you hold the button down.
Press "Mode" (bottom left) to change what you're adjusting, seconds, hour, minute.
Press the top right and bottom right buttons to adjust the number up and down.
Press "Adjust" again when you're done setting the watch.
To change date, alarm, alternate time, etc, press "Mode" to get to those functions before hitting "Adjust."
I hope that helps.
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Diesel Digital Watch DZ7069
I finally figured out how to set the time on this watch! Like others the included manual didn't have instructions for this model.
Hold down all four buttons on the watch, this will do a factory reset.
Hold down the top left button, which brings you into the configuration mode.
Pressing the bottom left button will cycle you through all the settings for the time. For each setting, the top right button increments and the bottom right decrements.
When you are done, press the top left again.
Dec 28, 2007 | Diesel Audio Diesel Watch
Casio Sea Pathfinder SPS2011V Wrist Watch Logo
23 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
