Question about Nitro BMW-482 Car Audio Amplifier
Need wiring diagram for bmw-483 1000w 4 channel amp bought used
Seems that the right subwoofer 10" is not as loud as the left we switched the wires and works great but then the other doesn't work right need to have a diagram
  • 239 Answers
Left + goes to the amp left - goes to the + on the right sub and the right - goes to the amp try that
rate pls
Posted on Aug 18, 2010
Just installed new front (Pioneer TS G4643R) and rear (Kicker KS4100) speakers in my 1989 S-10. The left front and rear speakers work great but the right ones are not so good. At low volume they both have...
It sounds to me like your wiring is having problems. An easy way to tell would be to switch your speakers around. Take the ones on the left that you know work, and place them on the right side. If you have the same problem, then that tells you the wiring is having problems. Another problem could be that the speakers are wired out of phase. What that means is that the positive of the speaker is connected to the negative of the radio or amp, and that the negative is wired to the positive of the amp. Do you have an external amp? Try switching them around, and let me know how that works for you.
Apr 11, 2011 | Kicker KS4100 4 x 10 Coaxial Car Speaker
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
I need a diagram of how to wire 2 gto 1202d subwoofers. i need to now whats the best way of wiring them to get the maximum power out of them and they will be getting wired on to a 4 channel vibe amp. if...
on 1 channel connect both poss. wires to poss of the amp.......on another channel connect both neg. wires to neg. of the amp...if there is a bridged switch select bridged on....i hope this helps
Jan 03, 2010 | Car Audio & Video
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
What is the wire diagram for the 3way bx35 boss crossover
Hello rew_smith,
The wiring diagram is silk screened right on the top of the unit. If your diagram is missing or obscured, you can get one directly from www.bossaudio.com.
The first 3 pairs of connections for subwoofer, front, and rear inputs coming from your receiver or head unit. Top is left channel, bottom is right channel. The 2nd set of connections are the outputs and matched in function to the first set. These are connected to your amp(s).
To the right of the input/output connectors are the 12V +, remote and ground screw terminals. The 2 switches and 9 controls allow you to set the high-pass frequency and output levels for the front and rear channels, and the crossover frequency, bass boost, phase, and output level for the subwoofer.
Hope this helps.
Aug 23, 2009 | Boss Car Audio & Video
Wiring h2 2ohm sub
ASSUMING YOU HAVE AN AMP FOR THIS SUB, CONNECT LEFT AND RIGHT JACKS, RED AND WHITE TO BACK OF STEREO RUN TO AMP AND THEN FOR A TWO CHANNEL AMP YOU JUST BRIDGE THE TERMINALS SO LEFT + ON CHANNEL ONE AND RIGHT - CHANNEL TWO
May 03, 2009 | Orion H2 15.2 Car Subwoofer
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Aug 22, 2006 | Audiovox BA200 Car Subwoofer
Nitro BMW-482 Car Audio Amplifier Logo
595 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
