Question about Kenmore 61282 / 61284 / 61289 Top Freezer Refrigerator
Water in my fridge
I have water building up in my fridge bottem. it looks like it is dripping from the ceiling from the fridge
  • jah2666 Mar 02, 2009
    i did exactly what u said with hair dryer and hot water but it froze up again about a week or so later ?
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Nov 18, 2008
Problem, fridge over a period of a few weeks or less goes from really cold to not so cold with ice buildup on the ceiling of the fridge section beneath the freezer compartment which itself does not ke
Hi, This will happen if you have a faulty defrost timer or the the heater is not working when it goes into defrost. The reason its not so cold after a week or so because the ice builds up & doesnt run efficently which is why when you switch it off & defrost it works great.
Nov 23, 2014 | Refrigerators
I have a GE refrigerator which leaks water. Point of origin of the leak is unknown but the water drips down the interior and pools at the bottem until it overflows and drips on the floor from the fro
You have a frozen drain in the freezer side of frig....take back panel off in freezer and you'll see your build up of ice take out ice and pour hot hot water down drain....make sure clear and clean then you're done....easy peasy....
Oct 02, 2012 | GE Refrigerators
Defrosting issue or need to replace refrigerator?
If your refrigerator was manufactured in 1999, it is way overdue for replacement.
Apr 05, 2017 | Magic Chef CTF2125 Top Freezer...
A lot of water leaking
You probably have a clogged drain line. Unplug the fridge for 24-48 hours with a towel by the drip pan for a simple fix.
Jan 22, 2012 | Kenmore Side by Side Refrigerator
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
Water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Jul 28, 2010 | Frigidaire FRS26R4A Side by Side...
Whirlpool ET19DKXFW01 water dripping and heavy frost
Hi this sounds like a blockage in the defrost drain. Follow this link to my tips and tricks which will give you instructions on clearing the blockage. If you have any other questions please feel free to comment. Mike
http://www.fixya.com/support/r3557045-how_to_clear_a_blockage_in_the_defrost_d
Dec 10, 2009 | Refrigerators
Moisture/Ice build-up in Refrigerator
ok first of all. the refrige is in the basement. do you know what the relative humidity in the basement is?
you can check this with a humidity gauge.
May 26, 2009 | Maytag Admiral Top-Freezer Refrigerator
Whirlpool ET1FTKXK Fridge not working
The reason you had water dripping from the top is the frig goes into a defrost cycle every 12 hours or so and melts the ice build up. Now your drain line for the water to go down to bottom of frig is plugged more then likely with ice. Take the cover off back of freezer and get some salt table salt be good. And put it in the drain hole located roughly in the center of freezer cabinet. That will take care of the drain quick. Now notice to see if the fan on the inside of freezer is on. My hunch is that it is not turning. You can replace the little fan motor make sure you don't damage the fan blades you will re-use them. Be sure compressor is on cause the fan only works when compressor is on. Let me know what you find out.
Nov 25, 2008 | Whirlpool ET1FTKXK Top Freezer...
Kenmore 61282 / 61284 / 61289 Top Freezer Refrigerator Logo
210 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
