Question about Apple iPhone Smartphone
My iphone dosen't make any sound when i slide to unlock it
When I side the button to unlock the phone is doesn't make the click sound.
    Problem Solver:
  • 12 Answers
Go to: Settings>Sounds>Lock Sounds. Make sure it's set to on. Also make sure the ringer switch is set to ring (no orange dot).
Posted on Nov 23, 2008
How to increas volume on iPhone 1st generation
if youv'e tried the volume buttons on the side go to settings and press on sounds.there is that little sliding thing on the top of all the other things alide that all the way up. If that doesn't work click twice on the button whithquare in the center. the apps you have recently used should show up in a compartment slide them to the right. then you should see your music slide it to the right one more time then you should see volume slide that all the way to the end I hope you get your voleme up.
-anna
Apr 18, 2013 | Apple Iphone 8gb A1230 1st Generation...
How do I turn up the volume control IPhone 3GS?
when you hold the Iphone in your hand with the round button with the square inside it on the bottom of the phone. turn the right side of the phone down to the floor while you do this look for 3 buttons on the side of the phone the TOP button must be pushed upwards at all times this flip switch is your MUTE switch pushed down it is in must mode switched up is sound mode.
Below this is 2 buttons the button just under the top flip switch is volume up the other one is volume down there ya go.
Please rate my solution and leave testimonial this is how i earn my achievements thanks in advance.
Apr 22, 2012 | Apple Cell Phones
My touch screen will not work
try an hard reset press on the home and top button together until the iphone shut down.
After turn it on by the upper button.
if that doesn't work you should go the apple store or your cell provider.
Dec 18, 2011 | Apple iPhone 3GS Black (16 GB)
There is sound on touching the icons but it doesn't work/ slide to unlock button also doesn't function
There is no sound touching icons. Never has been. There is only sound sliding the lock unless someone turns it off.
As for the lock not working. Chances are your screen is malfuncitoning
Oct 09, 2011 | Apple iPhone Smartphone
I want to create a privacy lock on my phone but is not working please help me
You can actually lock your iPhone so you can't accidentally use it. Well, i have this steps of solution that you need hopefully in can help you.
Find a button on the top called the sleep/wake button. The button's a tiny black button on the right side of the phone. It's not actually on the screen part of the phone, but on the silver part.
Press it and your iPhone will lock.
Unlock your iPhone by noting the locked screen. You'll see a small bar at the bottom of the iPhone with instructions to slide the bar to the right to unlock your phone actually on the screen.
Slide your finger along this bar to unlock your phone.
Remember, you can still get phone calls and text messages even when you've locked your iPhone.
Aug 29, 2011 | Samsung GTC3300 Cell Phone
My iPhone 4 sound isn't work like the clicks when
The problem you have is probably a sound option problem. This is uncommon, but very easy to fix!
To fix:
Turn on your iPhone Unlock it (put in passcode if applicable) Look around, find the app "Settings" Click it, and look for Sounds In Sounds, scroll down, and make sure that "Lock sounds" and "Keyboard Clicks" are switched on, and blue.
If this doesn't work, you've got a speaker problem.
Have a nice day!!
Jul 17, 2011 | Yahoo iPhone Apps
How will i unlock a password on an iphone with knowing the phone number
If you are faces with a password protected iPhone, you can still unlock and access iPhone favorites, address book, dial keypad, and voice mail. This trick is not a high tech technique, but just a simple unlocking steps to do. This simple steps can be done because iPhone has the security flaw. Gizmogo posted this steps like the followings:
Try to slide to unlock, tap emergency call, after that, double tap the home button.
Whoola, you will find yourself in iPhone favorites. From there, you could access other menu like address book, dial keypad, and voice mail.
If you are the owner and wants to avoid this security flaw, you could do the following.
1. In the iPhone home, go to Settings.
2. Click on General.
3. Click on Home Button.
4. Click on either "Home" or "iPod".
By doing this, when someone is doing double tap, he/she will be redirected to the unlock screen (if you choose HOME). Good luck.
Dec 19, 2010 | Apple iPhone 3G
This picture comes up on the front of my phone of a chord and a pic of the itunes app. I can't get to the main phone to use it
sounds like its stuck in DFU Mode
http://www.iphonealley.com/tips/save-your-iphone-with-recovery-mode
If iTunes doesn’t see your iPhone’s cry for help, you may need to invoke recovery mode. Although it’s an extremely helpful mode, how to get there isn’t very apparent. Read on for the how-to!
As arcane as “recovery mode” sounds, it’s actually very simple:
Disconnect your iPhone and turn it off by holding the “Sleep/Wake” button for about five seconds and then sliding the red slider. If your iPhone is already off, there’s no need to turn it on and then off again. Once it’s off, press and hold the “Home” button and plug your iPhone into a Mac or PC with iTunes installed. Keep holding the “Home” button until you see a dock cable pointing to the iTunes icon. iPhones running older software will display a yellow triangle and text which says “Please Connect to iTunes”. Once you see this image, you can release the Home button.
Open iTunes (if it’s not already open) and you will be told that “iTunes has detected an iPhone in recovery mode.” Click “OK” and you will be taken to the iPhone pane. Click “Restore” and you’re done, it’s that easy! Depending on the extent of your iPhone’s ills, it may take some time to do a full restore. Once you’re done, you should again have a perfectly working iPhone.
If this doesn’t solve your problem, you may need to restore using DFU (Direct Firmware Upgrade) mode. To enter this mode, plug in your iPhone and turn it off. Hold down the “Home” and “Sleep/Wake” buttons for about twelve seconds. You’ll briefly see the silver Apple logo and then your phone will appear to turn back off. Release the “Sleep/Wake” button but continue to hold the “Home” button until you see a message in iTunes stating that it has detected an iPhone in recovery mode. Choose “Restore” and you should be fixed right up!
If this doesn’t fix your problem, your iPhone may require a visit to the Genius Bar
Aug 28, 2010 | Apple iPhone 3G
My iphone will not ring on in coming calls
on the side, there is a button you can slide it can turn the phone on vibrate mode or on loud. its above the volume keys. just slide it up or down to turn the sound up.
Aug 02, 2010 | Apple iPhone Smartphone
My iphone will not ring and i checked the orange dot
Some users who have recently updated/restored to the new iPhone firmware 3.0 have reported to have got into a problem where their phone randomly doesn’t ring when there is a call nor does the keyboard or slide to unlock button sound anymore. I got into this problem as well after unlocking and jailbreaking my iPhone 3G with firmware 3.0, my iPhone suddenly stopped ringing on calls randomly, resulting in missing a lot of important calls.
So if your iPhone isn’t ringing sound on calls, or if you are unable to hear the keyboard or slide to unlock click sounds, then try the following fixes before you panic and call Apple support:
Fix #1: Push feature is currently not working properly on jailbroken iPhone’s. If you have installed an application which supports Push Notification System then try disabling the Push feature as it may solve the problem.
Fix #2: Try Resetting the iPhone: Settings > General > Reset > Reset All Settings. This will reset your phone’s setting to factory defaults. Your contacts, calendars photos and any other data will stay intact.
Fix #3: There is a slight possibility that your iPhone’s headphone jack may have got some dust or rust which is causing the phone to think that the headphones are still plugged in when they actually aren’t. Try blowing out air in the headphone jack or try plugging the headphones in and out repeatedly. This trick may solve the no sound problem.
Fix #4: Restore/Update you iPhone back and start afresh: If the above solutions doesn’t help in solving your problem then you will have to start from scratch by first restoring your iPhone to the the original firmware
3.0 from iTunes, jailbreak it using redsn0w and then finally unlock(3G users only) it using ultrasn0w. This has fixed my problem.
Fix #5: Install Insomnia from Cydia: Install Insomnia as your last resort. When you press the power button on the top, iPhone goes into sleep mode after 30 seconds, in the process turning off your WiFi, sound and other stuff. When Insomnia app (available for free from Cydia) is enabled, applications will keep running and sound & WiFi will stay connected when the screen is off. This should fix your problem if all of the above solutions have failed to fix it.
Dec 30, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
166 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
