Question about Whirlpool LER7646E Dryer
FAILS TO IGNITE ,UNPLUG &REPLUG AND WE HAVE IGNITION
I GET A FAINT GAS ODOR WHEN IT FAILS TO IGNITE, AFTER A SHUT DOW AND PWR DISCONNECT IT SEMMS OK FOR A FEW CYCLES
    Genius:
  • 1,028 Answers
Suspect coils on gas valve they will breakdown after several ignitions and not open valve for burner to light
Posted on Nov 18, 2008
Dryer won't ignite or ignites 1 out of 10 times then shuts flame off. Ignitor glows red but no flame just strong gas odor. I just changed ignition coils but no difference. Please help
call a serviceman gas should not be messed with brother thought he could fix and lived with burn scars the rest of his life
Apr 18, 2015 | Dryers
I have a LG dryer model dlgx3002w not heating.
It sounds like you didn't install the ignitor properly. Try re installing the ignitor, because it's opening the gas valve saying it's hot enough to light, but if it's out of position, it won't create proper combustion.
Nov 23, 2013 | Maytag Neptune MDG6800 Gas Dryer
When turn oven on can see the igniter coming on.but it doesn't light.can smell the gas
You need to replace your igniter. Very common replacement part.Igniters can look ok but can be failing and not drawing enough amps to open gas valve . Disconnect power before attempting.
hope this helps
Aug 15, 2011 | Whirlpool Ovens
WE SHUT OFF THE GAS TO THIS STOVE SEVERAL WEEKS AGO AND ARE READY TO RELIGHT THE STOVE NOW. WE CAN NOT FIND THE MANUAL AS TO HOW TO DO THAT. WE ARE CONCERNED MAINLY ABOUT THE OVEN AS IT SAYS IT IS A...
You should be able to just open the gas ****. That will supply gas to the gas to the stove. Once you've opened the gas ****, wait about 60 seconds and turn on one of the burners. The electric ignition should work to ignite the gas and you'll have your flame. If you smell a strong odor of gas, DO NOT use the electric ignition until the gas odor diminishes. In other words, when you first smell gas, you can try lighting it. If the smell of gas becomes strong, you DO NOT want to light anything in the area because an accumulation of gas can lead to an explosion. Be very careful.
If this helps, please come back to Fixya and rate my suggestion.
Jun 10, 2011 | Kitchen Ranges
No heat..revolves, blows ok...is there a fuse that shuts off gas?
Theres a fuse that shuts off the igniter. It can be the igniter or thermal fuse. If you see the igniter glowing but no gas coming out replace the coils on the gas valve. If that fails replace gas valve
Feb 13, 2010 | Kenmore Dryers
Gas smell during startup of GE hot water heater
yes, provided there is no excessive build up. The gas and air mix must be right before the mixture will ignit. a household stove will do this each time it's turned on. That's why yhe igniter sparkk hits about three times before it lights. proper venting will confine any fumes to the cimbustion chamber to be carried out the exhaust. If the odor is strong then have the appliance checked for safety sake.
May 02, 2009 | General Electric GE SmartWater Household...
Gas Dryer won't stay hot
There is a thermoelectric eye that says it is OK to keep the gas burner on. If this sensor is defective or blocked from "seeing" the gas flame is properly lit, it will turn off the gas flow (safety) override solenoid. With the unit unplugged make sure that the optical path on the upper right (1:30 CW position) flame tube inside sensor window is clean. The rattle you hear is probably the safety gas shut-off solenoid engaging. If you need more help, please ask -- SWT
May 03, 2008 | Dryers
Maytag gas dryer -
still may be solenoids belive it or not the coils could become weak and fail to pull open valve recommend changing both at same time
Apr 26, 2008 | Hotpoint NLL113EYWO Electric Dryer
Dryers Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
