Question about Epson Perfection V700 PHOTO Flatbed Scanner
Can't use the ''Film selection on epson V700
When I boot up the scanner alone or through photoshop/twain, the "film selection is not available.
This problem occurred once before when the scanner crashed during a scan. Reloading the driver didn't help, but uninstalling and reinstalling photoshop v6.0 resolved the problem.
Now its back. I just booted up the scanner yesterday and my only selection is "reflection" media. This is what I have done:
Tried the uninstall/reinstall photoshop solution... didn't work.
uninstalled the epson driver (v3.24a), my printer driver, and my monitor driver, then ran a registry scrubbing software to clean up the registry. downloaded another scanner driver from epson (v3,24a) and installed. Then booted up the scanner and accessed it from the Epson driver.... still no active "Film" selection.
Funny, but I thought this was a FILM scanner. I've cleaned the registry uninstalled all my other hardware drivers and still nothing.
Of Course, if I want to pay $80.00 I can go down to the local Epson service center and let them hook it up to another system to verify if its a hardware or software issue. My bet its software/configuration, and if thats the case, I'm out $80 and I still have the problem on my system.
Oh yeah, OS is windows XP.
Any help you can offer would be greatly appreciated
Thanks,
DRS
  • katiebenj Feb 06, 2009
    I am working with a Epson Perfection V700, running Mac OS X. I haven't used the scanner in about a month, but when I started it up today, I have been unable to select the film option. It is just greyed out.
  • Anonymous Mar 23, 2014
    Epson download site giving 404 error
  • 35 Answers
Make sure the transparency light cable that comes from the lid is plugged in to the back of the scanner. If the cable is unplugged for any reason, the transparency/film options will not be available.
Posted on Jun 14, 2009
I am using the Epson Perfection V700 photo scanner to scan dental xrays. Sometimes the xrays come out perfect, other times I get streaks across the image. Sometimes the streaks are colored, othertimes...
You have to use the "FILM AREA GUIDE" included with the scanner. This black plastic guide leaves a small area at the top of the glass open so that the scanner can calibrate itself at the start of each scan. Use the guide or leave at least 8mm between the top of your film and the top of the scanner glass.
Jan 24, 2011 | Epson Perfection V700 PHOTO Flatbed...
Does the soft ware in the V700 support early colour negative material ? I can find Ilford HP5 but not Ilfocolour !
There isn't a specific template for that film, but you can try out with generic settings and see how it goes. I rarely use the specific film settings from scanner software, and always prefer to adjust them to each roll I scan. Good luck with that! :)
Jul 09, 2010 | Epson Perfection V700 PHOTO Flatbed...
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Epson Perfection 4180 won't scan my negatives
cant scan film with epson perfection 4180. how can this be fixed?
Jun 10, 2009 | Epson Perfection 4180 Photo Flatbed...
Epson V700 - in the home mode rotate button has vanished
Try to do a reset all. Click on configuration, then click on others and click on the reset all button.
You may need to trash and re-install the twain driver. Please log on to epson.com to get the proper driver for your scanner compatible with your operating system.
Apr 28, 2009 | Epson Perfection V700 PHOTO Flatbed...
I cannot get clear scans from my photo negatives
If you are seeing pixelation, the issue is either insufficient resolution during the scanning process or a problem with the output device. If it's a focus issue, which will NOT cause pixelation, the problem may be the height of the negative holder. The Epson Perfection V series scanners have a fixed focus point which only adjusts between two settings depending on whether you select the film holders (which raise the film off the glass) or the film guide (which scans film directly on the glass) in the software options. If you are going to scan transparencies or negatives, familiarize yourself with the holder height adjustment issue and be willing to experiment with different height settings until you are getting optimum results. This is not documented much at all in the Epson user manual but there is a little bit about it, including some examples of results at different settings, here: http://www.photo-i.co.uk/Reviews/interactive/Epson%20V700/page_13.htm Apparently every scanner is slightly different so even though the lowest holder foot setting (default) is working best for some, other settings work better for others. On my V700, I have the feet on the film holders set to the highest setting plus I shimmed them with a 1mm piece of styrene before I could get the scans in focus. Once I found the right height though, I've been able to get beautiful scans from this machine. BTW, scanning negs directly on the glass will almost always result in Newton Rings.
Sep 08, 2008 | Epson Perfection V700 PHOTO Flatbed...
Huge difference in film scanning quality
For ARCHIVAL quality scans, there is no comparison. The Nikon wins hands-down. For making small prints and web sharing, either will work fine.
Apr 16, 2008 | Nikon LS5000 Film Scanner
Scanner incorrectly reads frame position on film
Yes there is
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Unable to use film adaptor
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
Epson Perfection V700 PHOTO Flatbed Scanner Logo
809 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
