Question about Maytag PAV2300 Top Load Washer
Washing machine does not add any water
When started, no water is added, the machine goes right into the aggitator mode. I removed the hoses to see if the filter screens were clogged, they were not.
    Genius:
  • 1,028 Answers
Pop top up look for small hose going from bottom of tub up into console remove either end if water runs end ck hose for restriction if hose clear water level switch may be stuck in filled postion try tapping it if works replace it don't trust it to stay fixed
Posted on Nov 18, 2008
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
When u start a cycle once it fills up and starts aggitating it leaks water out of a big white tube
By big white tube I presume that you mean the drain hose. It is critical that the drain hose be routed ABOVE the height of the console or top of machine. There is no drain vavlve, it uses physics. Hose too low and water runs out.
Dec 05, 2010 | GE Washing Machines
When I start the machine to do wash using any mode, there's no water coming into the drum but it keps on spinning. Defy DAW 366
remove hoses going to the back of the machine. There should be little screen filters inside where the hose goes. Remove them and clean, replace the hoses... This should fix the problem.
Aug 13, 2010 | Washing Machines
Our washing machine fills with water, aggitates,
dont know what washer you have but follow hoses to find pump as it will be blocked,may be able to drain by lowering drain hose into bucket
Mar 16, 2010 | Washing Machines
Washing machine continues to fill when starts
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 01, 2009 | Washing Machines
My washer will not fill with water. Whenever I select any wash cycle, any load size, or water temp it always does the same thing. It will start right into an aggitation cycle.
The plastic hose going to the water level switch is pinched closed.
Open the control head and find the water level switch with the plastic hose. Re-route the hose to eliminate the pinch.
To open the control panel locate 2 phillips head screws on the right and left rear corners.
Remove them.
Pull the control panel forward then rotate it to the back of the machine.
Mar 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Tub won't fill with water
You have a bad inlet valve. The valve is behind the hoses, you cant get to it one of two ways. Either through the top by removing the knobs and screws and face plate. or by removing the panel behind the hose
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
Aggitator operates as soon as the washer is turned on.
Your pressure switch hose maybe be plugged. This is happening because your washer thinks it's full of water.
Remove the clear hose from the pressure switch behind the control panel and blow through the hose. You are basically going to blowing air through the hose and into the wash tub. This will clear any restriction that is in the hose.
This is a common problem and a simple fix for your issue.
If you have anymore questions about this please ask. I will be more than happy to help you further.
Thanks
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
