Question about Lexmark X125 All-In-One InkJet Printer
How to remove the ink cartridge from printer
I have a Lexmark x125 printer. I am trying to remove the black ink cartridge to refill ink, but I don't know have to remove the cartridge from the printer. can you advise me what to do?
Gently pull the front panel towards you. then lift the back panel (towards the wall). your cartridges will come forward. gently pull them towards you to unclick then from the holders. there should be directions on the inside of the back panel on how to install/replace them. Hope this helps.
Cassandra
Posted on Dec 04, 2008
Lexmark x125 prints blank pages.
The printer cartridge could be
1) Out of ink and need to be replaced/refilled
2) The jets at the bottom of the cartridge may be clogged
3) Their could be a bad connection from the cartridge to the pads on the flexible circuit board in the printer.
To try and clean the printer cartridge I have heated a wet paper towel in a microwave oven and set the ink cartridge with the jet are in contact with the hot towel. That sometimes will clear the jets. If you see ink on the paper towel the jets are flowing.
Run the printer software to run the cleaning program and see if you get black bars on the paper. If not there is either not enough ink or there is a connection problem. Sometimes the connection problem can be fixed using a cotton swab in alcohol to clean the contacts on the cartridge and the flexible circuit in the printer. Be very gentle if you attempt this cleaning.
Aug 28, 2010 | Lexmark X125 All-In-One InkJet Printer
How to refill a lexmark x2600 black ink cartridge?
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Nov 05, 2009 | Lexmark X2600 InkJet Printer
I have lexmark x3580 printer i refilling the ink cartridge i have this massage in printer left cartridge Incorrect ( the black )
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 02, 2009 | Lexmark X3550 All-In-One Printer
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
Apr 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Is it possible to refill ink cartridge on Lexmark x6690 printer?
Take out all cartridges, switch printer off and then on again and let printer see that there are no cartridges. Do this 5 times, it resets the cartridges. Then install refilled cartridges
Apr 08, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Recently refilled cartridge #70 on a Lexmark x125 all-in-one printer/fax machine. tried test page and getting smears and streaks at bottom of page. test colored strips solid but black strips lines. do...
It sounds like bad cartridge. Inkjet refilling only works sometimes, If there was any old ink in the cartridge there could be a bad mix or even dried ink getting into the head
Aug 14, 2008 | Lexmark Office Equipment & Supplies
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Lexmarkx125 printer
same issue with me, using a genuine cartridge... cartridge sensor is probably stuck or hung... i know of possibilities to "trick" the sensors on refilled cartridges... i just don't have the documentation for that anymore... it came with my ink refill package
May 24, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Flashing error message
i have the same issue... i tried a few things, including resetting the printer (powering it off for 30+ sec and turning it back on) cleaning the nozzles on pc and manually... cleaning the connectors on the cartridge and cartridge caddy... all to no avail... a Lexmark rep told me I have a defective printer...
May 06, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
175 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
