Question about HP Photosmart C7280 Laser Printer
Paper feed It starts printing at the end of the page and paper won't feed properly, I cleaned the rollers and this is the 3rd HP Photosmart C7280 I have had and had to return it with the same problem. It starts with a paper jam and then never gets better. I have tried everything.
    Scholar:
  • 169 Answers
You can try a reset on the printer using the # and the number 6,holding them down while plugging in the power cord at the back of the printer.if it still does not work then you can try the same with the # and the number 9.If it still does not work,get your printer serviced.
Posted on Jun 25, 2009
How to clean the paper rollers for a HPC7280 printer?
This procedure was developed to assist the user in cleaning the rollers that feed the paper into
your inkjet printer.
I share a informative links, please open link and read documents.
More Help Click..
How to Clean HP Printer Rollers
http://www.museofineart.com/~museart/index.php/download_file/view/110/77/
Thanks,
HP Printer Support
Jun 24, 2014 | HP Photosmart C7280 Printer
Blank pages when printing
Altinis:
Remove the paper tray and look up into the paper pickup area. The roller there is the paper pickup roller. Under the paper pickup roller is a paper double-feed prevention pad. Take a "Q-Tip" dipped in alcohol and clean both the paper pickup roller and the double-feed prevention pad. That should prevent the paper double-feeds that you are experiencing.
Feb 24, 2013 | HP Photosmart B110a Wireless e-All-in-One...
Hp photosmart c3180 will not feed paper to print
Might be paper pick up roller warn out, clean or replace it.. For tech guys only: check for separation pad acting while service station performing? if not remove service station check separation pad leaver notch not in proper position in service station, position it. remove total mechanism up to pick up assm.. check pick up roller spring.. tension the spring. fix it back.. verify the print ...
Jan 09, 2012 | HP Photosmart C3180 All-In-One InkJet...
My C7280 is printing at an angle
You could try the recommendations from HP support for your model: (recommend cleaning feed rollers)
HP Photosmart C7280 Prints Crooked
Jan 07, 2010 | HP Photosmart C7280 Printer
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart C7280 Paper Jams
It isn't always about the paper. The video shows a few other things to check.
May 04, 2009 | HP Photosmart C7280 Printer
Hp Photosmart C7280 All-in-One doesn't print
Sorry, this isn't ASAP, but here's a solution on HP's website.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=3204785
The most important part of this is taking off the rear door / duplexer and cleaning the two rollers that you can just see inside the printer with the back off. Those two rollers inside the back of the printer (not the ones in the door or the ones hanging out the back when you take off the rear door) are the ones that pick up the paper and feed it up into the printer. Those rollers are hard to get to - long qtips are strongly suggested. If those get rollers dust or gunk on them, they get smooth and don't pick up paper as well.
Click the link for detailed instructions - don't just go with my summary of the solution.
Feb 25, 2009 | HP Photosmart C7280 Laser Printer
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
My printer The HP C7280 does not feed the paper, what can I do?
you can try to remove the rubber roller that pulls the paper into the printer. Once removed clean it with some rubber renew. If it is very smooth and does not have any texture left in the rubber, the rollers will have to be replaced.
Dec 05, 2008 | HP Photosmart C7280 Printer
Out of paper
My wife and I encountered the same problem with our HP 8250 Photosmart Printer. Me being an avid do-it-yourselfer, and a tightwad, searched tirelessly for a solution. HP was totally useless in providing information beyond what is posted on their website; which was all the service technicians would spew forth, both by phone and on-line. I had nearly resolved to buying the $50+ paper feed roller cleaning kit when I decided to look more closley at the machine. After romoving the rear access cover and watching the printer perform it's functions of trying to fruitlessly feed the paper off the paper tray; I noticed that the rollers were in contact with the paper and they were rotating normally, but there was just did not appear to be enough friction to feed the paper forward. The paper was new and was HP brand. I figured why not try and clean the rollers with some generic rubbing alcohol on a long wood handled cotton swab (available at most drug stores). Afterall, the HP site and technicians mentioned "DUSTY" rollers. I turned the machine off, disconnected the USB and power cables, and began cleaning as follows: Simply wet the cotton swab with the alcohol and gently brush/rub the rubber surface of one roller at a time, while rotating the rollers with another cotton swab using the wooden end. After several rotations of both rollers and a half dozen swabs, I replaced the rear access cover and turned the machine back on. My wife and I have printed pictures and documents flawlessly since. Total cost of the do-it-yourself cleaing kit: about $3.00.
I hope this someone else finds this solution helpful and as inexpensive as we did.
Thankx Fixya, for a great web site that pairs problems with solutions.
Mar 16, 2008 | HP - HP Photosmart 8250 printer
HP Photosmart C7280 Laser Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
