Question about Canon BubbleJet i320 Printer
Printer prints same material over and over.
Attempted to print a sheet of text. After I got the copy I required, the printer printed another copy, then another and so on. I shut the printer off, hoping to solve the problem. When I turned it on again, it continued to print the same text page over and over.
  • 461 Answers
Check the print spooler (double-click the printer in the Printers and Faxes folder) see if there are more jobs listed if so cancel them and power the printer off and unplug the power cable and reconnect and power on. Keep the paper pulled from the tray until it stops attempting to print. Also check the printer settings (right-click on the printer in the Printers and Faxes folder and select Properties and then Printing Preferences) to see if the default number of copies is set to anything other than 1.
Posted on Dec 31, 2008
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
C9600 OKI.....On the printed sheet there starts to be a light layer under the text. I goes from side to side on the sheet although the backround ought to be quite white. Any information of the end of the...
Perhaps drum exposed to sunlight too long. It will ruin drum.
Could be foreign material inside drum or printer.
Run heavy stock through printer with nothing on page, to do this-
Open up Word. type a period, or a comma.
Print 10-20 copies.
This may clear it up.
Mar 26, 2010 | OKI C5400 Laser Printer
Unwanted page does print on a print command
Have you tried uninstalling and reinstalling your printer driver software? If not, try this and also remove the power cord from your printer and plug it back in again before trying to print again.
Apr 28, 2009 | HP Officejet 5610 All-In-One InkJet...
C-7250 HP all in one appears to have a stopped up printer head?
Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK Inkypete
Apr 23, 2009 | HP Photosmart C7250 All-In-One Thermal...
I am not getting 100 draft copies per cartridge.
Purchase the 74XL cartridge for 3x the prints. You may want to consider a different printer or laser printer for more cost effective prints and reliability as your printer will most likely wear out before you want with that quantity of printing.
Jan 01, 2009 | HP Photosmart C5580 All-In-One InkJet...
My kodak 5100 printer is having problems printing black text
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the printhead:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Copies Poorly (black)
sounds like a resolution issue in the scanner settings.
May 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
No text
Check that your black ink cartridge has ink inside, eventually try a new cartridge , as ink may have dried up in old cartridge.
If you use a new cartridge ensure you removed cellotape from cartrige.
If cartridge is ok, then it is printer nozzle/head for black ink.
In this case do nozzle check / head cleaning in printer tools a couple of times.
If problem persist you may need to check and clean printer's head with cotton and solvent.
Mar 20, 2008 | Computers & Internet
Text printing problem
maybe your black ink cartridge is empty.....try replacing it... but before you do that try the clean up utility first it might work if its not empty.....
Feb 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon BubbleJet i320 Printer Logo
47 people viewed this question
old marine
old marine
