Question about Jensen JPA285 Car Audio Amplifier
Jensen JPA285 425 Watts 2-Channel Amplifier instalation
I just got this new van an it came with a
Jensen JPA285 425 Watts 2-Channel Amplifier but the wires are all messed up like all tweeker set it up with a bunch of house speaker wires i need to no what wires go where i no the power to the battery an the grounded wire but thats it i need to no how to be able to conect it to the radio now how do i so that >? should i use the house speaker wires or should i just buy all new wires ???
  • 1 more comment
  • hatchetcarer Nov 20, 2008
    ahhh **** i allready unpluged everything cuz the way it was set up there were live wires that wernt runnen to anything an it was fucken up my van an allmost set it on fire lol so i tulk out *** the wirein to try an make it beter im get bran new wires thanks for ur help tho when i get the newe wires hopefully itll be collor coded so itss b e easy
  • hatchetcarer Nov 21, 2008
    ya there brown but i mean u should see this wirering job lol it was really bad ill post a pic of how bad it is
  • ragonamuffin May 11, 2010
    What kind of radio are you wiring this to? make sure you leave all the wires connected to the amp! That is your only chance of figuring out how to rewire it if its unlabeled. I would get a multimeter and check for continuity on each end of each wire. either that, or if its close enough, try pulling on each wire. Good luck, it can be a pain I know!
  • 20 Answers
Yes, watch out for bad wiring! My father's 73 chevy caprice caught fire because of an amp that was wired in poorly. If you have a multimeter it shouldn't be too hard to find each speaker wire, as the speaker will show up with a certain impedance, Like 4 ohms of 8 ohms. Wiring it in phase is the real trick. For that you can only hope there is some sort of color code that the car came with, and there is a pretty good chance there is. I am assuming you are looking at the chopped radio wiring harness. There might be something like brown with a white stripe, and white with a brown stripe. It could also just be brown, and brown with a white stripe. You get the idea. They should all be wired in the same pattern, If they did not do this, then the some car manufactures just have better standards. I believe you can take a AAA battery and hit the two wires you know to be one speaker, and you should hear a pop from that speaker. I would be careful doing that if the speakers are really old, but it should be safe even then.
Its amazing what a 15 dollar multimeter can do in everyday electronics. My friend and I built an electric motorcycle, and obviously its very crucial for that, but I have used it for tons of things besides that. Especially old car wiring.
Posted on Nov 21, 2008
It says 75 watts rms per channel. what would the power,when u 2ohm load each channel?
If your amp is 2 ohm stable it will do 75 rms to both sides maybe a little more.
Apr 13, 2011 | Jensen LXA300 Car Audio Amplifier
Want to know how many wattes there is?
  • 130 watts RMS x 2 at 4 ohms
  • 180 watts RMS x 2 at 2 ohms
  • 360 watts RMS in bridged mode
Here is a good review of it:
http://caraudiomag.com/articles/jensen-jxp-720-car-stereo-amplifier
Not a great amp for the money really.
Feb 06, 2011 | Jensen JXP720 Car Audio Amplifier
What fuse do i use for my Jensen 2 Channel Bridgeable Amplifier with 300 Watts Peak? thank you.
Watts = Voltage x Current
300 = 12 x Current
Current = 25 amps
Sounds like a 30 amp slo-blo fuse would be about right -- you could start with a 25 amp and see if that holds it.
Charlie
Jan 05, 2011 | Jensen XA2150 Car Audio Amplifier
Power output
2 x 75 watts RMS per channel (2 x 100 watts peak)
150 watts RMS bridged into a 4 ohm load
Jan 03, 2010 | Jensen LXA300 Car Audio Amplifier
How many watts RMS are?
Hello melesk82,
The Jensen XA4150 is a 4-channel amp that outputs 75 watts times 4 channels into a 4 ohm impedance.
Hope this helps.
Oct 03, 2009 | Jensen XA4150 Car Audio Amplifier
Missing my manual
go to jenson homepage and click on support
Mar 31, 2009 | Jensen XA275 Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Protection light comming on.
I'd be inclined to check to make sure there isn't a short circuit somewhere in the output lines. Maybe a wire is crushed against the car's body or bare wires touching or badly fitted RCA plugs. All of these things could activate the protection circuit. If you have a multimeter it would make life easier but don't forget your speakers will show up as 4 ohms so that's not a short. BMW
May 31, 2006 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Jensen JPA285 Car Audio Amplifier Logo
439 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
