Question about Philips DVD-750 DVD Player
Philips DVD750VR Err 3 Message when trying to play VCR tape.
When I put in a vcr take into my dvd/vcr combo, it ejects the tape, displays the ERR 3 message and turns the power off. I tried putting in a head cleaner and it ate the tape. I'm affraid my 4 heads are bad. Thoughts?
  • Anonymous Mar 10, 2009
    Err 3 message due to VCR trouble. Try to play DVD but will switch to vcr mode with error message.
  • 308 Answers
SOURCE: Hitachi DV-PF33U DVD Player / VCR Combo
It sounds like the sensor to tell the microcontroller that the tape is moving is not working. If that is so, the VCR would probably do the same thing in FF or Rewind. If you end up taking this unit into a repair shop, have them check the DVD's software version (it should be 1.250) If below that number, have them upgrade that as well. You can check the version yourself by pressing 1,2,3,4 and then "display" on the remote while the unit is on and no disc in DVD. After noting the version, just hit "power" on the remote to exit this mode.
Posted on Jan 01, 2007
ice man
  • 68 Answers
SOURCE: dvd drawer will not open
seems like the rubber band is broken. no there is not secret back door to it..you have to open it and change the rubber band. it is not that complicated
Posted on Mar 26, 2007
SOURCE: DVD player does not read discs anymore
With some models of DVD player I know you can download a firmware update on your PC, load it to the DVD player and it wil fix some issues.
Finding those sites for download may be difficult though.
Posted on May 17, 2008
SOURCE: Samsung dvd/vcr combo, dvd says "no signal," was working, vcr wor
On the remote, clicked a botton on the bottom. Don't have it with me so can't remember which one. Will look and post answer. Thanks
Posted on Dec 08, 2008
  • 1348 Answers
SOURCE: ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Posted on Jul 07, 2009
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
My VHS tape will not eject from the VCR. I have a message flashing stating ERR. What can I do to eject the tape?
Hello
The mechanism of your VCR has jammed with video casette tape. If tape ribbon has got twisted around the drum motor head, or the belt that connected to eject [capstan] motor has elongated, this type of fault will occur. Either it will play, rewind, fast forward of eject. Just replace the belts first. In most VCRs the user can replace the belt from underside. Let the tape is there, if it is in, replace all the belts. Belts can be bought from most of the electronic spare part shops at your town. It will come as kit type, each model has its own belt kit, and you have to give them the exact model number of your VCR. Just open the cover of the VCR, and look for tape ribbon twist if any. If it is there, remove it carefully without making damage to any other internal parts, especially to video head. If necessary, cut the tape film. If tape twist is only the problem, it will be rectifed as this twist has been removed. If this also doesn't help you, replace all the belts. OK.
Jul 11, 2011 | GoVideo Go Video DVD/VCR Combo
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
Vcr/dvd combo, vcr no longer will play tape, when I press play, after a few seconds will eject tape.
Hi
Thanks for using FixYa. Please check the eject mechanism and the drive motor connected with the tape mechanism. Try and align the drive motor. Also check the push-pull arm of the tape mechanism and make sure that the springs connected with the mechanism are fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 15, 2009 | Philips Magnavox DVD/VCR Dual Player
The vhs tape will not eject or play it keeps reading Err.
the sensor that tells the VCR there is a tape in the player is bad or might need alined! (may cost more to fix then a new one!
Dec 08, 2008 | Daewoo DV-6T955B DVD Player/VCR
Dvd/Vcr combo
often if you turn off machine, then hold eject as you turn machine on tape will come out.
Feb 13, 2008 | Sanyo DVW-7200 DVD/VCR
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
VCR Tape playing problem
The mean time between failure for the rubber parts in a VCR is about the same as the rubber parts on your car - about 5 to 7 years. You are due for a belt job.
Dec 29, 2007 | Televison & Video
VCR tape playing error
It needs its belts replaced
Dec 24, 2006 | Hitachi DV-PF33U DVD Player/VCR
Philips DVD-750 DVD Player Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
