Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Problem with tv turning on and off
Tv turns on ,standby starts blinking, tv goes off ,standby blinks for several mins tv turns back on, goes off and so on,but lamp does not blink.sony said it could be the optical something but i cant remember what.can you help with this problem?
  • modestet Nov 20, 2008
    SAME PROBLEM
  • 320 Answers
Does the green light begin to flash when the picture disappears? If so, you have a weak lamp causing your TV to shutdown the picture. Replace the lamp with an original Sony lamp as the aftermarket lamps are known to have problems such as early failure and low brightness. Please be sure to rate this solution. Thanks!
Posted on Nov 18, 2008
My Sony tv won't power on its goes on then stays blinking on standby 14 blinks on red
Try unpluging the tv for several minutes and then plug it back in and turn it on and see if that helps
May 22, 2015 | Sony Televison & Video
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
TV goes off after turning on
did you change your lamp? if so check thermal fuse.. i have same tv, it was great for about 18 months then went to ****.. light engine will go out soon, cost between 2,000 and 600 bucks.. i have major complaint with sony atm. i know several several ppl with sdame prblem, might get a class suit started against sony, they knew and did nothing. I am pretty upset with them since i have always been a sony fan until this.
May 20, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My Sony tv screen blinks off and on and timer/standby blinks 5
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
Feb 26, 2010 | Sony KP-53HS10 TV
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony tv wont turn on, standby light just flashes
I had the same problem guys! This is what I did:
My T.V. wouldn't turn on. The standby light was flashing six times, then four, then seven...I called Sony and they told me to unplug it for a couple of minutes, then try it again...didn't work....BUT, I have found a solution:
Try unpluging your T.V. for 4 hours+, then turn it back on. Worked for me! It's called a "hard reset" by sony. I had my T.V. unplugged for the whole day though.
Nov 18, 2007 | Televison & Video
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
173 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
