SOURCE: computer beeping on startup
One long, two short is the POST beep code that indicates something is wrong with your display adapter (e.g. your video card).
Make sure your video card is plugged into your computer firmly. If it is an onboard card, you may need to get an external video card and plug that in to test if that is your problem.
SOURCE: Casio CE-3700 lockup
It sounds like you have a flat, or faulty backup battery. The machine has probably lost all programming. This is common if the machine has been stored.
Try this:
Turn key to program.
Turn power off at wall.
Hold JOURNAL FEED.
Turn power on at wall.
When you see '000000000' or 'LLLLLLLLLL' type 21151 (for Europe), or type 12300 (for USA) then press SUBTOTAL
If you still have trouble, just let me know.
Mark
SOURCE: I have a problem with cash button on TE 2400 cash register.
Hi.
Try this:
Turn key to program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
Mark
SOURCE: a till won't open the cash draw tried different
It usually means the drawer wiring has been shorted out at some stage and the internal fuse (most models have a drawer fuse on the main board) has blown. Occasionally the drive transistor may have blown open also.
If you want to have a go at it yourself and save some money, C-tech has a service manual here:
http://the-checkout-tech.com/estore/catalog/product_info.php?products_id=334
Once you have it, I can direct you to the relevant parts/ diagrams etc for drawer drive.
Testimonial: "seems a rational explanation of the fault, it would account for why it abruptly ceased performing. cheers!"
SOURCE: My acer aspire x3400 isn't working. When I press
first you need to disconnect your ram from mother board and turn on your computer
is there any beep sound?i long and 2 short?if yes it mean your ram was damaged, try connect another ram to your computer
and try to turn on your computer again
