Question about Mr. Heater MH75KT
MH75KT Contractor's Series Kerosene Heater won't stay lit
I fired up my heater for the first time this season and it runs in pulses, like it's too rich and won't stay lit, on-off, on-off in 1-2 second "puffs" - is there a mixture screw or something that I need to adjust? I can't find my original paperwork on this but it is only 2-3 seasons old. thanks
  • Marc Vacek Jan 17, 2018
    Needs new fuel lines
    New Friend:
Needs new fuel lines. Mine were cracked after 3 years
Posted on Jan 17, 2018
Heater will not lite
Posted on Nov 16, 2010
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
https://www.youtube.com/watch?v=k1nRieTELnk
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
https://www.youtube.com/watch?v=ve0nzByP6SU
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
https://www.youtube.com/watch?v=2EzoWdZLExg
Jan 11, 2016 | Mr. Heater Heating & Cooling
I have a Mr. Heater MH75KT Forced Air Kerosene Heater and it starts and the fan spins but it shoots fire through the cone section. I cant get it to start like it would during normal use and I cleaned the...
Discontinue use and take of house , this unit could start a fire. I would call the factory and talk to one of there Tec , because it might be an on going problem with other units.
Dec 07, 2013 | Heating & Cooling
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Heater will not stay lit after firing it up. Replaced wick and kerosene.
Two things usually cause the problem you noted. An improperly installed wick or the tails of the wick are not all the way into the tank. Therefore, it won't absorb enough kerosene for it to continually burn
Check out those two things and one of the other should solve your problem.
Feb 03, 2011 | Corona 23-DK Compact Heater
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dyna glo heater
The first thing you need to do is put some kerosene in it, it's a simple step that a lot of people tend to forget. After that make sure it's plugged in and turned on and it should fire right up. Hope this was helpfull poolmistress. You could also have your husband look at it, i hear he is pretty good with stuff like that.
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Mr Heater MH75KT - won't start with diesel
If the MH75KT is the correct model, then it is a Kerosene only heater. Fuels, like oil and diesel all have different ignition points.
http://www.mrheater.com/upload/newsletter/70276_MH_HS_50_75_125_175_210KT_REV%20A.pdf
See page 3 of the manual.
Feb 03, 2008 | Heating & Cooling
Heating & Cooling Logo
1,060 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
