Question about Canon EOS Rebel K2 with 28-90 lens 35mm Film Camera
Canon EOS Rebel K2 constant low battery indicator light
The low battery indicator light (icon) is staying on, regardless of how many times I change the batteries. The camera won't turn on, advance a new film roll, etc.
  • 44 Answers
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Posted on Dec 12, 2008
I put new batterys in my canon rebel eos k2 but every time I take a picture the battery flashes.Why is this happening?
hello, maybe, you have the contacts of your lens or your camera with dust.
this make what the camera works wrong,
you have to clean the contacts of your camera an lens with a Rubber to erase, and the camera must be ok
Jul 09, 2011 | Canon EOS Rebel K2 35mm SLR Camera
I just purchased a Canon EOS Rebel K2 35 MM film camera body. What lenses are compatible with this camera?
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Jan 25, 2011 | Canon EOS Rebel K2 with 28-90 lens 35mm...
Camera indicator in back that shows how many pictures are left wont shut off and it drains the batteries because of this , it is a canon eos rebel k2 model, thanks for any help
That's entirely correct and normal, but the battery drain caused by the film counter is absolutely insignificant: think how long digital watch batteries last and they have far less power than your camera battery.
If the battery drains rapidly when the camera is not being used then there is something else causing the problem. Make sure that the camera is kept with a lens cap on when stored and not in use and consider removing the battery, although doing so for extended periods means that the camera will lose it's memory.
Jan 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
My canon eos rebel k2 will not turn on even with brand new batteries in it. What could be wrong?
Dirty contact in the battery compartment, bad power circuit, bad switch etc. Too many things to be able to fix in this forum. Send it in for service or buy another used one, that may cost a lot less than getting yours repaired.
Nov 22, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Camera is constantly buffering and virtually nonresponsive.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 11, 2009 | Canon EOS Rebel XS 35mm SLR Camera
I have a Canon ESO Rebel K2 camera and my low battery light comes
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Aug 10, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Canon eos rebel t2 battery indicator
guido462:
new batteries - brand new? fully charged per spec?
Jan 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Canon eos rebel k2
That all depends on what you have your settings for. If you are not using the program mode, you'll need to make sure to check your Aperature and Shutter speed. Adjusting these might make your pictures come out better. Make sure to check your light meter, the needle or indicator should be in the middle for best results.
Jan 03, 2008 | Canon EOS Rebel K2 with 28-90 lens 35mm...
Battery
If this camera is a Canon Rebel K2 the problem may be that it might need a new main drive motor. I have replaced two drive motors in the last couple of days in these cameras. When the motor starts to go bad the film transport may stop in mid cycle and the battery check indicator starts to blink. The battery draw becomes excessive and the camera shuts down. Of course, there may be other problems but this a common one. Hope this helps.
Sep 25, 2007 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS Rebel K2 with 28-90 lens 35mm Film Camera Logo
375 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
