Question about Canon imagePROGRAF W6200 InkJet Printer
Error Code GARO W01035
I try to send a file to the printer (W6200) and I get this error, GARO W01035. If the printer does take the file, it will only print for a short time and then stop. I have done a head cleaning and it comes out normal. Please Help, Kathy
worldvet
  • 859 Answers
SOURCE: Canon MP500 Printer head error
Print heads for nearly all printers are rated at 2 years. You may also need to clean the tube from the resevoir at the ink supply to the cartridge and clean the working resevoir on the cartridge as well. If you are up to this challenge there is a how-to at your manufacturer's web site or you can have a tech do it. Most people, when they realize how inky you will be getting choose to have a tech do this.
It is best to use 100% denatured alcohol, from your hardware store, to clean these parts and tubing. But, you must take precautions.
DO NOT USE DENATURED ALCOHOL UNLESS YOU READ AND FOLLOW THE DIRECTIONS ON THE BACK OF THE CAN.
I'm not kidding about the precautions. I do all this stuff outside when there is a breeze in the air and then I stay up wind of my work.
If you have any questions whatsoever just feel free to comment back to me.
Regards,
Worldvet
Posted on Jun 07, 2008
  • 3 Answers
SOURCE: canon ip1880 continous paper jam error on screen
first you turn off your p.
Posted on Mar 26, 2009
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Posted on Jul 08, 2009
SOURCE: cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Posted on Nov 11, 2009
SOURCE: Error code 03130031-2F13
lol,, see this
Posted on Dec 11, 2009
Error code GARO W1234 keeps coming up why
1. unplug data cable
2. go to service mode
Aug 26, 2015 | Canon imagePROGRAF iPF8000 Printer
Hi there. I have an on-going issue with this printer. I'm using Windows XP, sp2 on a Mac Pro. While printing I get these error messages on a regular basis: Error: undefined Offending Command: (what...
sounds like it's trying to send pcl code to the printer and can't read it, need make and model of printer
and what is the print file your trying to send, does it only happen on this type of print file?
Apr 27, 2011 | Office Equipment & Supplies
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
Printhead error
Just check your printedhead that could be not inserted properly of just clean the printerhead with a piece of cotton with alcohol then insert it back to the printer after you clean it. Then try to print if the problem are not solve just replace the printerhead.
May 29, 2010 | Canon imagePROGRAF W6200 InkJet Printer
Printhead error
perform troubleshooting procedure in manual
Mar 19, 2010 | Canon imagePROGRAF W6200 InkJet Printer
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
To reset the 'MT CARTRIDGE FULL SOON' error.
Enter Service mode Hold down the paper source and online button at the same time, hit the power button once.Continue to hold down the paper and online buttons until you see the printer name "Canon W6200" on the printers LCD display, then release the two buttons.The printer will initialize & enter service mode.
In service mode, scroll sideways until you see the 'Initialize' menu, scroll down to 'W-ink', and press enter. At this point I did something (scroll sideways and hit enter I think) and it came up with 'New W-ink Cart' Hit Enter to get '=New W-ink Cart' and Online to Accept. I powered down and back up, error all clear.
Jan 08, 2008 | Canon imagePROGRAF W6200 InkJet Printer
Print head error
Did you try cleaning the contacts where the print head fits? You might try a qtip moistened with rubbing alcohol or electronic contact cleaner. Sometimes ink will find it's way onto the contact area. Also, make sure you removed the contact protect tape from the new cartrige assembly. Sounds obvious, but I've forgotten this a time or two.
Jul 08, 2007 | Canon imagePROGRAF W6200 InkJet Printer
Canon imagePROGRAF W6200 InkJet Printer Logo
488 people viewed this question
old marine
old marine
