Question about Dell Dimension 4600 PC Desktop
Scratching (static) noise coming from computer speakers
I have purchased new speakers but still have static noise coming from my speakers. I have run diagnostics on the speakers to no avail.
  • jkbthackray Nov 23, 2008
    the noise is constant. Even when the volume is low. And it just began. We have had the computer for approximately 5 years. Everyone I have talked to.. suggests to get a new sound card. Which poses a new problem, can I replace it easy enough or should I take it to someone that really knows what they are doing?
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Posted on Jan 21, 2010
  • robrussell87 Nov 28, 2010
    I believe I have the same problem, but I'm running windows 7. I can't find the speaker properties, and therefore the "pc beep slide bar". Any suggestions would be appreciated. Thanks!
The volume coming from a computer speaker is scratching I dont know why
Posted on Mar 30, 2009
    Sergeant:
  • 395 Answers
If you have low output from computer and turn volume on speakers all way up you will get noise. You must use Control Panel Audio controls to turn up volume and turn down volume on speakers.
Are they powered speakers? Same noise on headphones?
If you need good quality sound I highly recommend the Xonar D2 sound card - the quality improvement is amazing even using small PC speakers! You would not beleive your mp3s could sound so good!
Posted on Nov 23, 2008
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
One of the speakers is making a static noise when I turn on the organ . Model #CTK-900 . Thanks Heather
It sounds like the organ and the computer's speakers power source is on the same circuit. I would suggest purchasing a outlet strip that has noise reduction/surge protection, and plugging the speakers power source into it.
Nov 10, 2010 | Casio Computers & Internet
Left Speaker Jack only produces static
Hi!
That is probably happened to an aging speaker.
Consider buying a new one or try to rewire the coil inside the speaker magnet.
Jun 01, 2010 | Bose Companion III Computer Speakers
The speakers are making a very scratchy noise. They are hooked up to my desktop computer. When first purchased last year, they sounded quite good. Now, they are very scratchy and not on high volume.
Do you by any chance have any other wireless device like a cell phone near the speakers when you hear this?
Any kind of device that has a magnet field will cause scratching sounds on the speakers. I discovered this quite by accident with my old Boost mobile phone.
Debbie Mahler
MICE Training, Technology & Education
mice.org
Oct 24, 2009 | Bose Companion 2 Series II Multimedia...
Scratching clicking noise coming from speakers
maybe you bumped a wire going from computer to speakers.
Are you using the speakers built in the samsung?
try another pair of speakers that are connected to the monitor.
Oct 10, 2009 | Computers & Internet
Static noise in Yamaha HS50 monitor
Sounds like the voice coil is damaged on the woofer. If you GENTLY press in on the woofer cone, and release, you should not hear any scratching noise. If you hear noise, the woofer needs replacement.
Aug 18, 2009 | Yamaha HS50M Main / Stereo Speaker
Static only in one speaker
When you say static that they both work but one is noisy or are you saying that the only one is making a noise and nocoherent sounds coming from either
Aug 03, 2009 | Genius SP-F350 Computer Speakers
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
2.0 CH USB POWERED SPEAKER SYSTEM
The static is probably coming from the computer sound card itself. Turn the volume down on the computer mixer it should limit the static you are hearing.
Jun 07, 2008 | Audio Players & Recorders
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
Dell Dimension 4600 PC Desktop Logo
4,704 people viewed this question
Alun Cox
