Question about KitchenAid KESC307 Electric Kitchen Range
Oven is set on celsius, how do you change it to ferienhiet?
  • 833 Answers
You manual will tell you this:  open the oven door.  Push broil.  The indicator in the panel will change to F.  You're done.
Posted on Nov 20, 2008
How do I change the baking degrees on my whirlpool accubake range from Celsius to Fahrenheit?
You can just convert from Celsius to Fahrenheit yourself by going to this site. Just type in the Celsius and it will convert automatically. And, it's fun to learn how to do it yourself. O.k, don't want to do that? You don't say if your oven is electric or gas or what the model is. Check this website and I hope it helps:
Good luck
Apr 10, 2015 | Whirlpool Kitchen Ranges
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
It sounds like you got the electronic oven control to expect temperature settings in Centigrade (Celsius) instead of Fahrenheit. Check your owner's manual to find out how to change it back to Fahrenheit.
Jan 26, 2015 | KitchenAid KGRT607 Gas Kitchen Range
do you mean celsius ?depending on the recipe and if your talkin about celsius you can covert it to fahrenheit . 180c is 356f
Apr 18, 2014 | Kitchen Ranges
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
oven can be changed from Fahrenheit (°F) temperature to Celsius
Oct 26, 2012 | Wolf Range Ovens
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Mar 22, 2011 | Microwave Ovens
The stove is stuck on celsius. I pressed and held the CANCEL AND BAKE buttons for 3 seconds and nothing happens. I don't know how it got on celsius. How do I get it back on Fahrenheit?
You can get Whirlpool manuals from
Just got it from there:
The temperature is preset at Fahrenheit, but can be changed to
Style 1 - Electronic Oven Control
To change: Press and hold PRECISE CLEAN for 5 seconds, and
"TEMPERATURE UNIT CELSIUS" will appear in the display.
Repeat to change back to Fahrenheit.
To exit mode, press OFF/CANCEL.
Styles 2, 3 & 4 - Electronic Oven Controls
To change: Press and hold BROIL for 5 seconds. A tone will
sound and "°C" or "°F" will appear on the display. Repeat to
Mar 18, 2011 | Whirlpool GR563LXS Kitchen Range
Cant reset celsius to farenheit control cant cook in celsius
If the model number you referenced this question under is correct, you can change cook settings between Celsius and Farenheit by pressing and holding the BROIL button for 5 seconds. A short beep will be heard and the temperature setting will change.
These instructions are listed in the owner's manual. If you no longer have a copy, you can obtain a replacement at Just enter your model number under the "Manuals" link and you should find your manual listed in .pdf format. These manuals can be viewed, downloaded or printed for FREE.
If the procedures I provided do not work for your range, please post back with your complete MODEL NUMBER (located on a nameplate around the oven door, or lower drawer (if equipped) and let me know. I hope you find this information helpful.
Dec 22, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Oct 19, 2008 | Whirlpool Ovens
KitchenAid KESC307 Electric Kitchen Range Logo
509 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
