Question about Microsoft Xbox 360 Console
1 red light on in ring
I have on red light on
    Scholar:
  • 120 Answers
Hey psrbailey, this should help you out. http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Posted on Nov 18, 2008
How to Stop the Red Ring of Death on Xbox?
Hi Carolyn,
- notice poor game performance (if your games start taking a long time to load, or they become stutter or crash, it may be indicative of a looming hardware failure)
-notice poor system performance (if your system locks up, even when not playing games, this is a sign of hardware failing).
- understand the different light codes
Green-green lights indicate that console is powered and operating properly
1 red light-Hardware fault. Usually followed by E74 code on TV
2 red lights-overheating error. If the console becomes too hot, the system will shut down and display this light code
3 red lights-general hardware failure also known as the red ring of *****
4 red lights-AV cable isnt currently plugged in
If you do get red ring of *****:
- purchase a fix kit
-have console professionally fixed
-have console sent in to microsoft
-Prevent red ring of *****-understand what causes hardware failure
-keep your system in a well ventilated area
- avoid long gaming sessions
-keep system horizontal
-avoiding stacking items on xbox
-clean gaming area
-dust xbox
Oct 20, 2016 | Video Game Consoles & Games
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox 360 freezes after being on for a couple of minutes. How do i stop this
If it freezes and then the next time you turn it on has red lights on the console display check out the corresponding Microsoft articles for the number of red rings on the display. They appear in quadrants on it.
1 red ring
2 red rings
3 red rings
4 red rings
If you do not have any rings, your console may just be overheating. Give it a while to cool down and if that doesn't work, give Microsoft a call: 1-800-4MYXBOX. Good Luck!
Jan 05, 2010 | Microsoft Xbox 360 Console
Red rings
Depending on how many you have it means different things:
1 red light - scaler chip E74
2 red lights - overheating
3 red lights GPU and CPU have burnt out
4 red lights - the AV cable is not in correctly
You can fix all of these errors yourself or you can send it in to have it repaired
Dec 23, 2009 | Microsoft Xbox 360 Console
I have 3 red lights flashing and my disk tray gets stuck
when u have 3 red flashing lights its called RROD or red ring of death. u have a 3 year warrenty on that so just sent it in and for the disk problem, if u still have ur warrenty , you can just send it in so they can fix it.
Dec 08, 2009 | Microsoft Xbox 360 Console
A red ring is around my xbox start up button
How may lights are showing up?
3 red light is GPU and the CPU overheating,
2 red lights is general overheating
1 red light is E74 and 4 red lights is the av cable.
For the 1, 2, 3, red lights you will need to get it fixed you can either send it in to do this or repair it yourself
Oct 26, 2009 | Microsoft Xbox 360 Console
2 red rings after the xclamp fix
Yesh...4 red lights means you didn't have the component or hdmi pluged into the system and tv. 3 lights means there is some soldering problem in your 360. 2 lights means your 360 is overheated. For the 2 lights normally you can fix that with letting it cool for a while and give it some room around the system to run cooler. However by using the towel trick you you caused the soldering to run and now it's probibly miss soldered. I recommend you ship to Microsoft or sell it.
Mar 22, 2009 | Microsoft Video Game Consoles & Games
1 red light flashing
1 red light indicates that there is general hardware related problem with the console, 2 red lights indicate the overheating of the console, 3 red lights indicate the red ring of death and 4 red lights indicate that you need to tighten your AV console wire. If you get any of the problems and your system is under warranty, you can ship your console directly to Microsoft and you will get back your Xbox 360 red ring fixed by the manufacturer, however it might take more than a month and you will also have to bear the additional shipping charges. If your warranty period is over, you will have to pay additional amount of $140, if you choose to send the Xbox 360 to Microsoft for red ring fix. Further you will have to also bear the shipping amount and wait for at least a month for getting your console back. However, you can avoid this and can repair your console your own. There are many good guides available at Internet and you can go through any one of them and can fix Xbox 360 red ring problems your own.
Oct 22, 2008 | Microsoft Xbox 360 Console
Night button and incoming calls
The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
The green ring of light on my xbox360 keeps going to red
how many red rings do you get is it red ring of death with only 3 lit or what?
Jul 02, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
