Question about Zanussi 23 in. ZDi6895S Built-in Dishwasher
Zanussi 23 in. ZDi6895S Built-in Dishwasher - Error code H2
Hi when I turn on the dishwasher an error H 2 flashes on the display and a program cannot then be selected . can you tell me the cause of error code H2? Thanks
4 Suggested Answers
SOURCE: Zanussi DE540X Dishwasher
I have the same problem. First fault was caused by poor workmanship on the assembly of the PCB. There is a relay (the largest component on the board) which was badly soldered and caused some arcing resulting in solder splattered around the plastic casing and a lost electrical connection. This relay switches the mains voltage on to the heater i.e. 240V around 8.5A for a 2kW heater. (26 ohms suggests a 2215W heater for the case mentioned). Re-soldering this connection solved the problem for about a year. Now the dishwasher is showing the same problem. I have tested the relay and it is operational, but does not seem to be turning on during a wash cycle. A new board costs around £100. Zanussi will not even provide the technical details to allow a home fix. I will post my finding if I get to the bottom of this problem. It may be to do with electrical temperature sensor. My hunch is the controlling PCB is cheaply made and will not last a reasonable lifetime. A dishwasher is in itself a very simple piece of equipment with only a few valves, a pump and a heater so should not give problems in its first five years of life subject to normal usage. I will not consider purchasing any Zanussi appliances in the future.
Posted on Jun 20, 2007
  • 185 Answers
SOURCE: How to replace heating elemant on Zanussi DE6850 Dishwasher
is your water heater set on 120 degres
Posted on Mar 31, 2008
SOURCE: zanussi ls9 dishwasher
check your boiler,maybe there is no water there
Posted on Aug 03, 2008
  • 10 Answers
SOURCE: Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Posted on Dec 15, 2008
0 characters
1 Points
UL error code on frigidaire dishwasher
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Apr 24, 2015 | Frigidaire 24 in. FDB635RF Built-in...
What does error code 155 mean
This is not error code. If a fault occurs on your device it will be displayed in hexadecimal code for example:
Newer models: i10, i20, i30 ....... i90, iA0,.............iF0
Older models: A0, A1 ........ A9, AA, Ab,............. Af
or C0, C1 ........ C9, CA, Cb,........... Cf
Because that I believe that the digit number "155" that you see on the display means the duration time (minutes) of selected program. Also see in user manual how to cancel selected program and choose new one.
Nov 04, 2014 | AEG 23 in. Favorit 50750Vi Built-in...
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Aug 24, 2014 | Zanussi Dishwashers
The Heavy Duty and the Daily Cycle lights are
to better assist you can you provide me with the ERROR code, if is any.
Thank you
May 15, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf162 built-in dishwasher error codes
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Feb 10, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDi6895S Built-in Dishwasher Logo
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
