Question about Panasonic PT-47WX5347 47" Rear Projection Television
Convergence Problem Hello, My Panasonic PT-47WX53 developed a symetrical "ghost" arc of blue. The arc is vibrating in line. It goes up about 1/3 of the screen and ends at the lower right and left corners. Horizontal convergence works but vertical is way off and not adjusting. Any thoughts? D-I-Y Serviceable? Thanks in advance!
    Sergeant:
  • 308 Answers
The convergence IC's have been known to cause similar problems and both would be replaced at the same time. Not an easy job for a DIYer. I would get a repair shop to fix it.
Posted on Dec 20, 2006
There is an arc of varios colors at bottom 1/2 of screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Picture went funny on my PT-47WX53 last night... a blue ghost like arc appeared mirroring the lower portion of the images displayed on the tv a few inches above where they were positioned. Most of the...
You need to replace convergence ICs in TV for correct converge picture.
Below is an image of D board and ICs are marked need to replaced.
If you are familiar with TV repair and knows basic electronics then can do this job OR call TV tech to fix it.
Jan 29, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem, blue ghosts
you need to replace both convergence ICs they are both STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 47wx53 covergence issues
Is the power indicator flashing three times? If so the Ics have shorted shutting the set down. You will need two STK392-110 convergence ICs. You can get replacement ICs at the following link with free installation instructions.
Aug 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX5347 47" Rear Projection Television Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
