Question about Honeywell Programmable Thermostat Heater
Where does the T Wire go on the RTH7400
I've got a trane system. I'm installing a Honeywell RTH7400 Programmable Thermostat. Where Does the "T" wire terminate?
The t wire is for an outdoor anticipator reset. If you dont have a terminal on your thermostat it does not have to be used. Just tape it off.
Posted on Jan 19, 2009
I have just installed a RTH7400/RTH7500 thermostat. The wires are seem to be in the correct place, all functions are working, with the exception of no heat will come out, only cold air? I have set all...
Check function 0170 to make sure it is set on the proper type of heating system. Its a long list and specifics of system type make a difference. Also, Ive learned the hard way to always go by function, not color of wire. If you tossed the instructions they can be found on the Honeywell website https://customer.honeywell.com/resources/techlit/TechLitDocuments
Nov 16, 2017 | Honeywell Focus 6300B 5-2 Days...
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
New thermostat honeywell RTH7400 cycles oil furnace every 10 min.
rth7400 maintains a 1 degree differential in temp so 10 minute cycles are not unusual.
Vinnie
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth7400 keeps turning furnace on
check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Nov 21, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Jan 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
393 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
