Samsung DLP HLN5065- picture is messed up with horizontal and vertical lighter lines- this happened for about a week- then the pic totally cleared up, crystal clear for 8 or 9 days -- then it messed up again for about a week -- then totally fine for a week-- now it's acting up again... starts out fine, then the lines, then clears up for a minute, then the lines, clears up over and over , then turns to almost black and white vertical lines. We are puzzled that the problem came and went in the beginning and we don't know if it will go away or WHAT the deal is !
  • 283 Answers
Probably a loose ribbon connector inside the TV. If so it's easily solved.
Posted on Apr 28, 2017
  • 43 Answers
SOURCE: vision 42 inches plasma tv
It sounds like there is a problem with the tuner inside the television. Your best bet is to send it in for service.
Posted on Jan 30, 2008
  • 133 Answers
SOURCE: tv repair
If the color is available by itself you may be able to buy it from tritronics on the web. It is not as simple as some may claim to install . Some require the light engine to be sent in to get rebuilt. Make sure you know what you are doing . Having it rebuilt can be costly sometimes avg. between 300.00 to 500.00 if you do it your self . Call a tech if your not sure you can safely disassemble your set.
Posted on Feb 27, 2008
  • 3459 Answers
SOURCE: Philips PTV840 55" rear projection TV
You canget a Factory Service manual from The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Posted on Jun 24, 2008
SOURCE: black bar
On a non H.Def plasma, there is a PCB that runs along the bottom of the screen that is attached to the screen by a several brown/gold colored flat ribbon cables. I've seen where this ribbon cable is not seated properly in the jack. The ribbon cables are generally responsible for that section of the screen. Next possibility is the PCB itself is defective.
Not to scare you, but the plasma screen itself is a possible suspect.
Posted on Jul 31, 2008
SOURCE: Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Posted on Aug 30, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from
Samsung LCD Loud Noise and Green Vertical lines at Start up ... > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
LNS4695DX/XAA Samsung tv vertical and horizontal lines on picture - all components
Thats usually caused by the Tconn board and or its connection also samsungs have been plauged with tab bond issues with the LCD panel itself. Send a pic of the issue to and they will be able to tell you whats happening with it be sure to include the model number with the pic
Mar 13, 2012 | Samsung Televison & Video
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Samsung dlp
do they look like jail bars ,running from top to bottom.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
