Question about Crosley CRS40 Manual Defrost Compact Refrigerators in White on White
Freezer my freezer keeps frosting up the fins on the back of freezer when this happens the fridge part gets warm. this is suppose to be a frost free fridge
  • 478 Answers
Not if it says manual defrost in the name.
Posted on Mar 12, 2009
Refrigerator doesn t get cold
If your refrigerator is frost free and been running for a year or two then here is the solution.
Why would you need to defrost a frost-free freezer? Because they do sometimes get frosted up! This is especially common if the door gets left open for long periods without being noticed, then shut again, thereby trapping lots of moist air in the freezer, which can only come out as frost. The problem is that if their defrosting cycles don't manage to cure their problems they get frosted up at the back, out of sight. If your freezer seems to be struggling to keep things frozen but is otherwise working normally you should consider defrosting it before concluding it is broken.
I have found the best way to defrost my not quite frost free fridge-freezer is to empty the freezer compartment contents into the fridge and switch it off overnight, leaving the fridge door shut and the freezer door open. By stacking all the frozen food together as tightly as possible, ideally wrapped in something to help insulate them (such as newspapers) they stay cold for a long time. In the morning I get in my scruffy clothes and wipe up the puddles caused by the visible frost in the freezer and any puddles formed underneath the appliance. However this is only half the story. To ensure all the frosting has been removed from the hidden parts of the appliance I get my hair dryer and blast warm air into all appropriate crevices from inside the appliance and from behind it.
Mar 07, 2014 | LG Refrigerators
Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Jul 14, 2010 | Kenmore 64802 Top Freezer Refrigerator
Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Aug 17, 2009 | Refrigerators
AMANA ARSE66MBW SIDE BY SIDE FREEZER COIL FINS GET TOO FROSTED ?
The frost should be uniform on the coils. Uneven frost pattern is a sign of low freon. Most systems are sealed but a qualified tech can recharge the system after finding the leak and cap it off.
Jul 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Frost free combo unit fridge keeps getting warm
Hi: You have a bad defrost heater or defrost timer. I'm not familiar with the brand but the heater will be below the evaporator coils in the freezer ( in the back behind a panel.) When you do your defrost that your dad told you to do, it will work until it frosts up again. You are doing the work of the defrost heater. I hope this helps, Jeff
Jun 02, 2009 | Belling BE811 Bottom Freezer Refrigerator
Whirlpool arc7612. Fridge not getting cold. Freezer obviously working as it frosts up despite being 'frost free'. Slight gap in door seal near top of door. Last time we had this happen I unplugged it for a...
You have to replace the door seal. The seal may be a mundane technology and it isn't the only technology making a refrigerator frost-free, but it is the most important one. Warm moist air enters through the gap in the door seal, condenses on cold surfaces and freezes. The frost interferes with airflow and prevents the system from keeping the fridge cold. Turning it off for a day allowed the frost to melt.
Aug 03, 2008 | Whirlpool Refrigerators
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Crosley CRS40 Manual Defrost Compact Refrigerators in White on White Logo
163 people viewed this question
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
fta777
Colin Stickland
Colin Stickland
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
