Question about Magellan GPS 320 GPS Receiver
Magellan 320 Trying to update the 320s firmware to 3.15 and somewhere along the line the gps screen locked up showing "software upload mode active" datasend or any program will not recognize it nor will any of the key-pads change anything ...it is locked in this state...Appreciate some help here... E-mail jamesnejaim@dodo.com.au regards...jim
  • jim nejaim May 09, 2007
    I sent mine to Perth Alan, They couldnt fix it ! Jim...."bloodnut"
I have the same problem as you. I was able to contact Magellan on 1800 644 o33. in Western Aus advise me the download on the Magellan site is USA only. I will be sending it to them they may be able to fix problem? Alan
Posted on May 08, 2007
Cant not get watereays on explorist 500 in canada
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive.
Double-click on the update file to begin the installation process.
Follow the on-screen instructions .
Jun 17, 2011 | Magellan GPS
Magellan Explorist 500
The necessary map software is not installed - did you buy the unit with software?
Mar 19, 2008 | Magellan eXplorist 500 GPS Receiver
Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release Notes This update applies to Magellan RoadMate 1200. It includes the following features, fixes, and improvements:
Improvements:
  • Point of interest (POI) Search Improvements reduce POI search times
  • Map Draw Improvements improve zooming, panning, and time to display the map
The software update version corresponds to your current software version:
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
You can locate your software version by following these steps:
  1. Start at the Main Menu.
  2. Press the arrow on the bottom right of the screen.
  3. Select "User Options"
  4. Select "System Settings"
  5. Select "Next"
  6. Select "Product Information"
  7. Your software version is on the line titled "Firmware Version"
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
Feb 07, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Magellan triton locking up
Dan, download from jungleghost.com and reload the same firmware FORCED UPDATE software and rewrite over the firmware.
To do this just attach the GPS to the computer and turn it on and set it for Connect to PC.
Then fire up the firmware software and let it do its job.
JG
Oct 22, 2009 | Magellan Triton 500 Handheld GPS Receiver
Frozen Magellan
Big problem .. you had a bad firmware download and the unit is now stuck in the development mode. Two solutions .. 1) return to Magellan for a replacement. 2) If not in warranty .. there is a third party repair center on the internet .. use your browser and search for 'magellan triton repair'
JG
Oct 12, 2009 | Magellan Triton 500 Handheld GPS Receiver
My sportrak Pro shut off while I was doing a firmware update and now does not turn on
To put a Sportrak into Software update mode that doesn't appear to turn on (Most likely due to corrupt firmware).
Hold NAV and MENU and press POWER. This should put your Sportrak into software upload mode. Once your GPS is in software upload mode you can use magup in expert mode to upgrade the firmware.
Jim
Apr 15, 2009 | Magellan GPS
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
CAN NOT GET MAP ON GPS MAGELLAN EXPLORIST 210
try updating the firmware from the magellan website that fixed mine.
Oct 29, 2008 | Magellan eXplorist 210 GPS Receiver
Reciever will not power up
The same thing happened to me. It turns out the USB to serial adapter had issues. Anyway to fix try this. Hold the NAV + Menu and press the power button. Your Sportrak should start up in software upload mode. You can then use the Magup program in expert mode to bring your GPS to life. I had to find a computer with a serial port to fix mine.
Jim
Aug 10, 2008 | Magellan SporTrak GPS Receiver
Firmware Update Fails
I'm not sure this will help, but per Magellan (see below), the firmware update must be run twice as your firmware is earlier than version 3. I have a GPS 315 with v2.03 and can't find a cable to update mine. My GPS 315 does not appear to have a cable connection either, just a screw port on the back for a carrying strap. Was your homemade cable wireless? How did you make it?
You must follow instructions exactly to avoid corrupting your unit's flash memory.
  1. Select the .zip file and save it to your hard drive. Open the .zip file using WinZip.
  2. Connect your receiver to your PC using the PC or Power/Data Cable.
  3. Turn on the receiver and press the NAV key.
  4. Make sure the batteries are at least 50% full.
  5. Select the MAGUP executable file from your PC.
  6. Follow the instruction until you see the message Upload Complete.
  7. If your unit's software version is earlier than 3.00, you will be prompted to turn the unit on again and load the software a second time. Follow the instructions.
Jul 19, 2008 | Magellan GPS 315 GPS Receiver
Magellan GPS 320 GPS Receiver Logo
254 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
