Upgrading an old motherboard
It has 16MB of memory, 166 Mhz intel processor
Would like to know if I can put a faster processor and what type?
  • Michael Frederick Nov 19, 2008
    Thank you Ekse.
    Its an old working computer lying there, just decide to make use of it.
    MB 8500 TUD-A   ver 1.3
  • 13,433 Answers
Probably a intel 200 Mhz. What does it say on the CPU socket? socket 7? heres intel 200mhz should work http://www.pacificgeek.com/product.asp?c=201&s=1080&ID=33236&P=F
Look around ebay
http://shop.ebay.com/items/__intel-pentium-mhz_W0QQ_kwZintelQQ_kwZpentiumQQ_kwZmhzQQ_armZ1QQ_armiZintelQ20pentiumQ20250Q20mhzQQ_armmZ104QQ_ckwZ250QQ_fromfsbZQQ_ruuZhttpQ3aQ2fQ2fshopQ2eebayQ2ecomQ2fitemsQ2fQ5fQ5fintelQ2dpentiumQ2d250Q2dmhzQ5fW0Q51Q51Q5farrQ5A1Q51Q51Q5ffromfsbQ5AQ51Q51Q5ftrksidQ5Am270Q512el1313QQ_trksidZm270Q2el1313
around 200 - 300mhz.. it debends on what motherboard it is, I would say the 200mhz cpu will work.
I would personally give it away or throw away / recycle and buy a cheap desktop pc.
Posted on Nov 18, 2008
Need to upgrade processor, need to know most recent and best available for this mobo
Here's the table of supported processors from the manual for your board:
If you need a copy of the manual, you can download it here.
There's really very little to be gained by upgrading the processor on this board, unless it's the bottom-rated Celeron. Here's one source for the Pentium 4 at the top of the table. There are others, I just picked this one because it was first. This is a discontinued, fairly old board with a socket 478 design. This limits the processors it will support, and also the availability of parts. Simply sticking in a little faster processor won't make a big difference in performance.
What will help, if you haven't already done so, is to add memory. Putting in the maximum the board can support (or is supported by the operating system, if it's a lower amount) and using RAM matched to the processor speed will let was you have already work its best. And upgrading your video card may also be helpful for many applications.
Jan 01, 2011 | Intel D865PERL Motherboard
Power on ok but no display. ram not detect
First disable the onboard VGA then put in a known good AGP graphics card to see if you can get through the POST if your BIOS i rejects the RAM chips it should give you a short series of beeps this would indicate that the memory is not compatible as a rule of thumb PC2700 speed memory is for a motherboard and processor with a 133Mhz FSB this is quaded to 533MHz. you can usually place faster memory but not slower memory look at the table below for rated Frontside Bus Speeds.
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200/PC2700*/PC2100 400/333*/266 MHz (min busspeed 200Mhz)
533 MHz PC2700/PC2100 333/266 MHz (min busspeed 133Mhz)
400 MHz PC2100 266 MHz (min busspeed 100Mhz)
Dec 06, 2010 | Intel KD865GRH 10 Pack (KD865GRHPAK10)...
I have ATXmodel intelceleron1.2Ghz cpu1.2 cache 256KB Intel 810E chipset motherboard can i upgrade my processor to pentium 4 and ram to 512mb
No, u can't. ur motherboard is designed for pentium III processors with FSB -133 MHz, Socket-370 type. Pentium 4 processors have 400 MHz FSB, 423 Socket at least. But yes for memory, u can upgrade it to 512 MB.
Sep 26, 2010 | ASUS Intel 810E Chipset CUWE-RM...
Upgrade intel celeron processor 798 MHz
it is better to use intel core2 dueo or intel quad core processor
Jan 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Nov 01, 2008 | Matsonic MS9317E Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
Upgrading CPU not booting BIOS
Key Features
Form Factor Micro ATX
Compatibility PC
Chipset Intel 865GV
Compatible Processors Intel Pentium 4
Front Side Bus Speed 800 MHz
Technical Features
Integrated Input/Output Ports USB 1.1 x 4 • Serial Port x 1 • RJ45 Lan Port x 1 • PS/2 Mouse x 1 • PS/2 Keyboard x 1 • Parallel Port (ECP/EPP/SPP) x 1 • Floppy Port x 1
Expansion Slots PCI x 3
Storage Controller Type(s) Serial ATA x 2, DMA/ATA-100 (Ultra) x 2
South Bridge Chip Intel ICH5
Processor
Socket Type Socket 478
Max supported CPUs qty 1
Memory
Number of Memory Slots 4 x DIMMs
Supported RAM speeds 400 MHz
Max Supported RAM 4 GB
so this is the board..no doubt that the cpu fits and is a good choice for you.
however,if the old one works fine and this one ,even if it is new,does not wiork,the only rational conclusion is that this one is malfunctioning ,maybe from the factory,or maybe one of the pins doesnt make a real contact.
check very attentive the integrity of the pins and of the cpu socket in the motherboard.
there are also some cases that the motherboard doesnt support the high Frequence of the new processor,but that was a problem for the old PCs..I doubt you have it with your motherboard.
I suggest you to bring it back and to ask for a replacement,or at least go with it to  a specialised cervice and let them check it.
sorry for not beeing a huge help to you,so dont rate my answer if you dont feel to..
bye bye and good luck..keep me up to date with your situation
bye
Feb 06, 2008 | AOpen MX4SGVI-4DN2 (91.8B810.407)...
UPGRADE
U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
Jan 14, 2008 | Soltek SL-65KV2-T Motherboard
Asus A7V8X 1 gb sim
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
Aug 23, 2007 | Abit BL7-RAID Motherboard
Computers & Internet Logo
348 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
