Question about Canon PIXMA MP780 All-In-One InkJet Printer
MP780 paper jam
Hi, i noticed you had the above problem recently - did u fix it? If so could u pls tell me how, thanks.
my email is
  • 390 Answers
You need to open up the unit as if repalcing a cartridge and get a torch and really look hard for the jam it can be really tiny. Look in and under cartridge roller (paper roller too) and is the cartridge aligning itself when you open the unit so thta acartridge can be changed? Good luck.
Posted on Nov 21, 2008
Canon PIXMA MP780: The Clear Paper Jam alarm does not go off, although I have cleared all the paper out of the printer; turned it off, unplugged it, sprayed all the orifices with canned air; and turned it...
Turn off the printer. Open the Rear access door and clean the rollers with lint free cloth ( upwards just like the paper is rolled )
This should fix the issue.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 03, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Tried all the above to fix paper jam, never even made it through 1 toner and the thing still says paper jam
You have a borken sensor or
You need to replace motherboard of printer
that cost to high you beter replace your printer
Pls vote us to keep us alive
Nov 20, 2010 | Dell 1710n Laser Printer
Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
MP780 "check printer"
5200 is a printhead error, you may just need a new printhead. They do wear out, and just like a light bulb, they go out when you least expect. The part number is QY6-0049-000.
Jan 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Says it has a paper jam but there is no paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My PIXMA MP780 is still flashing check the printer then press ok - an error msge ##357 keeps coming up. what does this mean pls?
This is an error in the position of the paper feed unit.
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Look in the sheet feeder too. If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Keeps telling me paper jam but seems there is no at all
possible hardware problem.. on the part of printer..
i thnk you can do is un install the driver and try to re install again
Aug 25, 2009 | HP LaserJet 3200 All-In-One Printer
Pixma MP780 paper jam
Sandra, on the feed swich which way is the arrow pointing to the front feeder? or to the back feeder? Get a bright flashlight and inspect the back very carefuly. I had the same problem and found a label off of a shirt inside, don't ask me how it got there I havent a clue. But it did fix the problem. You can also try turning it on and off a few times.
If the arrow is pointing to the front paper feeder then the jam is in the front, if it is pointing to the rear that is where there is a problem. Hope this will help. Leo
Mar 15, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon mp780
Normally this can be caused by
1.) damaged gears
2.) damaged feeder motor
3.) damaged paper holder(the pins that grab the paper)
in any of the above cases you will need to take apart to see what the problem is.. if its the motor then you can change it..
if it with the feeder it self id suggest you consider buying a ney one,, even if you manage to change the gears or the feeder pins you may never be able to get it to pull correctly, eighter pulling twisted or constantly causing paper jams.. The choice is your but i'd say buy a new one
Jun 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
56 people viewed this question
old marine
old marine
