Question about Air Tools & Compressors
Air compressor trips breaker
Had 220 outlet installed for an Ingersoll Rand Model SS3-E (older model) air compressor (230 volt/15 amp). Plugged in air compressor, it ran for a few seconds (maybe 6 or 7 sec max), then tripped the breaker. Tried several times, but it tripped the breaker each time. Its been sitting for about a year without use, so I don't know if this has anything to do with it. The outlet was installed by a licensed electrician, so I'm pretty sure it was installed correctly. He installed a 40 amp breaker as well. I don't have an owner's manual nor can I find any information on the internet so I don't have a lot of additional information.
  • Anonymous Dec 31, 2008
    i have a hydrovane 3hp, every time i try to switch it on it runs fast for a split second, then goes slower and then trips the breaker, in total only running for ten seconds, every time doing the same and tripping the motor. motor is also getting hot. this is on a 240 volt supply. please help
  • Anonymous Feb 12, 2009
    i have a 480v ingersoll rand compressor that does the same thing. also been sitting for a while,
    Problem Solver:
  • 4 Answers
Check the ground wire most common mistake
Posted on Nov 19, 2008
My compressor keeps tripping the breaker
breaker needs to be motor rated to allow for the surge on inital startup
Feb 14, 2013 | Ingersoll Rand - Rand Type - 30...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
805 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
