Question about Acer AL1711 17" LCD Monitor
Processing auto configuration
The power button dont
turn off monitor
processing auto configuration
keep on
flashing
what should i do
    Novelist:
    Scholar:
  • 141 Answers
Check your settings in "Power Options Properties".
Control panel/ power options/ advanced/ under power buttons make sure you have "shut down" when you press the power button on your computer.
I hope I am understanding your problem correctly. If not pls. explain what you mean by and when processing auto config. keeps flashing. Is there a black screen or a windows interface?
Posted on Dec 11, 2008
Screen Problems
Why do you keep selecting auto configuration? You have the option of manual configuration, don't you? That is there in case the auto does not provide the results you want. So just set it manually to however bright you want.If it just will not go as bright as you would like, the remaining possibilities are aging backlight, inverter, or powerstrip capacitors which are all within your display.most re[pair shops will not even attempty a reiar of an LCD display, and if it turns out yours is deteriorating, you need to think about a new one. Unfortunately the problem with LCD monitors is that they just don't have anywhere near the life of a CRT.
Jun 18, 2010 | Gateway FPD 1520 15" Flat Panel LCD...
How do i stop my monitor auto configurating? I have a AOC LM500 monitor and every 5 seconds the screen goes black the it auto configures... i dont know how to stop it
Your auto-configuring settings are located on your monitors settings. Depending on the monitor, there should be a settings button somewhere on the monitor itself. In the settings there will be an option to change the monitor to your settings or "auto configuring". You'll know what to do from here.
I hope this helped.
Apr 15, 2010 | Computers & Internet
Computer monitor keeps auto adjusting screen
I have a Benq that was continually auto adjusting, I used electronic cleaner spray on all the controls (a good spray) and now there is no problem, suspect the controls were sticking, especially the on/off and the auto adjust button
Dec 20, 2008 | Computers & Internet
Monitor will not turn off and keeps flashing the words Auto processing
it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
Sep 15, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Acer LCD AL1711 Monitor Flashes Colors
Main power supply, and or the backplane power supply, and or the backplane lamps usually cause this.
The fix is to try new modules using the process of illimination. Once the defective modules are determined, the new ones must stay in the monitor.
That is the process used to service this monitor.
Jerry G.
Jul 15, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
Monitor keeps flashing "Auto processing"
Hi
Do a factory or monitor reset from the monitor menu.
Jan 01, 2008 | Gateway FPD1975W 19" LCD Monitor
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Processing auto configuration keeps coming up on my monitor
Help! I want to get rid of the "Processing Auto Configuration"
Dec 07, 2007 | HP w19 19" LCD Monitor
Acer AL1711 17" LCD Monitor Logo
986 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
