Question about Samsung CXJ1331 13 in. Combo
Can i hook up an x-box 360 to a samsung tv model cxj1331?
Is it possible?
I recently purchased a ilive and tried to hook it up to my Samsang DLP 1080 TV but could not get any sound. What am I doing wrong?
Posted on Nov 18, 2008
Kenmore model 105.79202990 refrigerator runs continuously
calla service repairman it possibly needs freon added and they are the only ones that can do it .
Nov 12, 2015 | Kenmore Refrigerators
1999 EX. Why is it hard to start?
Possibly dead battery.
Possibly out of gas
Possibly fouled spark plugs
Possibly almost everything.
If you were to give us some symptoms we might possibly be able to offer possible problems with solutions.
Aug 24, 2015 | Honda Accord Cars & Trucks
My toshiba satellite p305d s8995e wont power up
Possible power supply, possible battery. Possible on off switch. Possible hard drive though "post" should work even if the Hard drive didn't. Most likely power supply or its connector.
Feb 27, 2015 | Toshiba Computers & Internet
Blend door for heat some times does not open understand that it is control by motor
1 Possible bad actuator/servo (motor)
2 Possible HVAC control head problem
3 possible 'binding' blend air door
There are other possibilities....
If you need further help, reach me via phone at https://www.6ya.com/expert/ralph_2f0886b7d6af32ce
Jan 24, 2014 | 2002 Ford Mustang
2000n vw beetle wont go more than 30 mph
You're in LIMP MODE, the system is preventing any further damage to your car by limiting the speed insisting that you see a service center ASAP.
I see a P0702
17086/P0702/001794 Contents [hide] 17086/P0702/001794 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG) Possible Symptoms
  • Malfunction Indicator Light (MIL) active
Possible Causes
  • Control Module faulty
Possible Solutions
  • Replace Control Module
Nov 06, 2013 | 2001 Volkswagen Golf
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My 2008 Harley FXDC is throwing a code P55PL6, whats this mean ?
No such code so recheck and post a comment with any real codes. P is part of a possible code. 55 could be part of a possible code PL is not a possible part of a code. 6 could be a part of a possible code. What is your problem that you need to display a code for? That might also help narrow down you problem and your possible code.
Mar 08, 2012 | 2008 Harley Davidson FXD Dyna Super Glide
Android on apple Ipad, is it possible? that might be an interesting thing to do I guess. if you guys here have any idea then please let me know how to do it
It is not possible android runs on a different platform then ipad
it is not possible without rewriting the whole software from scratch
hope this helps
Feb 11, 2010 | Apple iPad 16 GB 3G Tablet PC
Samsung CXJ1331 13 in. Combo Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
