Question about Indesit W 123 Front Load Washer
Will not spin
I have a 6 year old wg834txc indesit washing machine it washes normally but it will not spin what can be the cause. in my opinion it is that electronical part on the back and at the bottom of the washing machine. if you know the technical name of the part please let me know. i would be pleased to have a solution from you for my problem.thank you.
    President:
  • 1,294 Answers
When your water does not drain or spin, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked. There is a small door on the front, below which is the place you have to clean out first.
Posted on May 22, 2007
Have old Indesit WG1130 which will only spin with light load. Towels won't spin at all
Hello, this is normally a motor or printed circuit board problem on this machine but can also be the timer, all are fairly expensive and you will not know which it is without testing.
Apr 14, 2011 | Indesit Washing Machines
Kenmoore washing machine no longer spins during normal wash cycles
sounds like your spin cycle belt has come off or broken. it,s a simple fix at a repair shop.
May 02, 2009 | Washing Machines
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Indesit Prestige Line 822
i have this! 4 is a normal wash cycle 7 is a spin 5 an 6 seem to be quick washes an never tried 1 2 or 3!!! hope this helps!!
Jul 20, 2008 | Washing Machines
Re washing and drying
Hours? It sounds like your machine has a problem.. Have you tried clearing the filter on the outlet after the drainage pump? The Indesit only has a 1200 spin speed so it's not the most efficient drier anyway (rated B for spin efficiency).
Personally I dislike Indesit as they release some models which do not permit replacement of the bearings because the innner and outer drum assembly are crimped/pressed together during manufacture. Instead of replacing bearings and seals (At most about £35.00) you would need top buy a complete drum assembly at about £125.00, and throw away a large lump f stainless steel. Presumably Indesit want you to throw the entire machine away, and to buy a new one. Not a brilliant idea in my opinion, as it is unlikely that a frustrated ex Indesit owner will but an Indesit as a replacement, and that sort of wastage (bearings last around three years in regular family use) makes a complete nonsense of energy efficiency ratings. The cost of manufacture and disposal over a three year usage period will have a massive carbon impact in comparison to the energy efficiency savings even of the most efficient of machines.
The planet can't afford to buy cheap machines and then thropw them away.
Apr 28, 2008 | Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Washing machine not spinning
Check your brushes in the motor. Have a good torch with you. You will see the brush holders and the brush sticking out. With a small screw driver lift the brushes back up into the holder to see if you have any travel.? A front loader can cut out a set off brushes about every five years.
Nov 30, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
111 people viewed this question
Top Indesit Washing Machines Experts
jimorris77
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
