Question about ViewSonic VX922 19" Monitor Flat Panel
Two problems vx922 Black screen of Death and vx910 no power
VX922 .... This monitor will flash for second and I will see a little Blue "digital" in right hand corner and background picture then it goes back to black ...
I can hit the number 2 key and after a brief delay the screen will flash for second then the back to black ...
VX910 ... is dead as a doornail, kaput, No power what so ever
  • 55 Answers
You may want to tey another computer or another cable or update your video card drivers. Otherwise look very closely and see if you are able to see a very faint image of your background picture or icons if you have any.
Really im not kidding it might be a backlight issue.
Posted on Apr 22, 2009
VX922 only shows "No Signal" on black screen
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
May 23, 2011 | ViewSonic VX922 19" Monitor Flat Panel
My Viewsonic vx922 was working fine until this morning. The computer had a problem and I restored it to the original factory settings. I had to download the drivers for my Radeon card to allow me to do 2...
Looking like there is an issue with the powerboard on the monitor. This problem you are having appears to be common with this monitor, with a lot of them failing for no apparent reason
Jan 05, 2011 | ViewSonic VX922 19" Monitor Flat Panel
I have a Viewsonic VX922 My led power goes on and off and the screen flickers then finally screen is black.
Defective power board can cause of on and off the led power, the boated electrolytic capacitor of secondary power supply and inverter area, shorted semiconductor of inverter area. The electronics repairman can fix this.
Sep 20, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Having trouble powering up my Viewsonic VX922. See the analog data, but have to power down for 20 sec (several times) to get the digital data on the screen
bob_loopeker, If you know that your pc is ok with different monitor then you will need to inspect the power supply board inside your VX922. All you need in the way of info is here on fixya!! All you need to do is read and make decision on what to do. Spend some time reading in my fixya profile or do "ctrl" key and click on "vx922 19" monitor" that is highlighted in light blue text above. May need new capacitors installed on unit's "switch-mode-power-supply" printed circuit board. hopre this helps. 12fixlouie
Mar 17, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Green light flashing on and off and computer screen will turn on when feels like it
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is YouTube video (do a search) showing how to disassemble the VX924 (very similar to the VX922) and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.
Feb 28, 2010 | ViewSonic VX922 19" Monitor Flat Panel
My monitor is getting off
I have a similar issue. A search at Tomshardware web site suggests that faulty capacitors are the issue and that this is a widespread problem certainly with the VX922. Several guys on the Tomshardware post claimed that replacing the capacitors solved the problem (their units were out of warranty anyway).
Jul 20, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX922 - black screen of death and the blinking (mocking!) green led
Really if this happens then you may want to contact viewsonic to see if it still in warrant. Reminder that most of their monitors have a 3 year warrany from the date of purchase. So make sure that you have your proof of sales/receipt/POP/invoice or what ever you want to call it ready. This model is old so they will ask for it if its a first time repair.
Oct 28, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic Monitor problem, blinking LED light, no picture.
you guys......you don't have a software (driver, refresh rate, etc.) problem. When you first power up the monitor, do you get any display at all (ex, "analog input" or "No input signal")? Of course not - that's because you have a hardware problem with the monitor. Go here and watch the youtube video on how to take apart your monitor and find and replace the "domed" capacitors that have blown:
http://www.tomshardware.com/forum/247964-33-viewsonic-vx922-monitor-black-screen-green-power-light-flashes
Fortunately I only had 1 ($1.76 at Radio Shack). I replaced it in less than 30 minutes and my monitor showed "no input signal" upon powerup as expected because I wasn't connected to my pc which is full of all kinds of drivers and refresh settings, etc.
Aug 16, 2007 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VX922 19" Monitor Flat Panel Logo
351 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
