Question about Williams 2509612 Ceramic Mid-Size Heater
Gas flows to long before igniting.
My girlfreinds house is old and the furnace is a Royal Jet Flow FG-2-55 Gravity Vented natural gas fired furnace.
I cleaned the thermal coupler and flame sensor and the furnace now burns longer and works great! Except, now when it starts the gas flows for about 1 to 2 seconds before it ignites. This causes a good flash and about a 6-inch flame flashs out of the venting. Needless to say this is not good.
did I do something wrong, or do I need to adjust the pilot flame making it larger or do I need to replace something?
  • m. mitchell Nov 19, 2008
    I cleaned the burners and crossovers. The furnace ignited great the first two times then began doing the same thing. It seems to be getting worse as far as the length of time from the gas flowing and then burning.
    Problem Solver:
  • 17 Answers
Try cleaning the crossovers between the burners. Also look closely at the flame and make sure that the burner is firing all the way to the pilot. Sometimes its just a few little holes that vent a little gas to give the flame a path to follow will be stopped up and cause the condition you describe
Posted on Nov 18, 2008
Boiler won't fire the pilot is lit.
Flame sensor not picking up flame and won't release /open gas valve
Mar 16, 2016 | Hydrotherm Gas Fired Boiler Hvx-105 Power...
Where can I find a manual for a Royal Jet Jr, model EG2-50 Gravity furnace.
I am looking for that exact wall furnace to replace one that is not working well. In fact I need two of those EG2-50 Junior Jet
Jan 22, 2016 | Heating & Cooling
Patio glow outdoor propane fire pit does not stay lit
Fire pits motivated by gas. Need suffocation. A natural fire needs oxygen. Gas fires need suffocation. Take the wood or rocks and make it tighter over the gas holes. Meaning Pile the rocks on top of gasoline tighter or more generously so the gas and the flame are not coming out hitting straight oxygen. Give the fire something to hold onto. Natural fires need the opposite. Propelled fires need a sauna /steam room / hot rock type of relationship.
Aug 13, 2014 | Heating & Cooling
Coleman h 90 gas furnace will not start up when thermostat is turned up
The gas valve is not lifting hence no gas flow , check pressure switch if fitted jump out thermostat see if it lights ,
Jan 10, 2013 | Heating & Cooling
THE PILOT DOES NOT STAY LIT AND WE HAVE GONE SEVERAL TIMES COULD IT BE THE SENSORS
Sounds like you may have to replace the thermal coupler. check your local hardware store for a replacement for your model.
Dec 02, 2010 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Won't start, has "varnish" from fuel
Does it have a fuel pump or is it gravity fed? If gravity fed, when you rebuilt the carb, did you make sure that the main (power) jet orifice was totally clean? No varnish or residue in the hole. Pressurized air or carb cleaner spray into the jet is a good way to test flow restrictions. It sounds like a clogged main jet or a vacuum leak at the carb to manifold gasket. You might want to flush the gas tank and replace the gas cap also, as evaporating fuel over time will leave behind varnish deposits if the cap doesn't seal, even though it is a vented cap.
Jul 31, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Goodman gms9090 furnace
Based on your description I would guess that there is a "leak" somewhere between the gas valve and the actual fire. Use soap bubbles to check the connections at the gas valve. Also check the gaskets in the Gas valve the same way. Lastly there may be a cracked or misaligned burner causing the "leak". Best of Luck!
Jan 29, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
We have a old house and the gas hot water heater and the central heating unit is vented out an old chimney and the heater is building up condinsation, how do i vent the heating unit out the wall, unstead...
actually if you vent your furnace by code, it would probably be cheaper to have a chimney liner installed up the old masonry chimney. you may be able to buy a kit and do this yourself. any time a new furnace with a draft inducer on it is installed, it must be vented into the proper flu material. if it was vented into your chimney, it may not have be installed by code for your area. you may talk to the instaled if they are still available and maybe that can return and do it correctly. if you leave this vented into your masonry chimney, the acid content of the exhaust will ruin the chimney. a liner will also get rid of the water problem you have.
Jan 26, 2009 | Heating & Cooling
My Honeywell gas furnace won't fire up. The pilot is working , the fan will turn on if set to manual, but won't fire. I live in Canada and am freezing. thanks.
is this a power vented system if so check the ventr motor . it must run first alowing the gravity swtch to make and send 24v to the gas valve- if its not a vented unit sounds likely you have a main valy or posibly a mercury or thermo couple problem. hope this helps.
Oct 07, 2008 | Heating & Cooling
Williams 2509612 Ceramic Mid-Size Heater Logo
223 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
